pan hard rod bolts STUCK!
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Does anyone here have some good advice on getting these bolts out. I have tried heat, pbr, hammer, and cutting these bolts off. My blade broke before even making a scratch so its not cut yet. My next move is getting a torch and cutting the bolts that way. I am going crazy over here.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: pan hard rod bolts STUCK!
Was the blade you were using for metal or for wood?
Car: 91 Trans Am
Metal but it was kinda a cheap blade so I might have to get new ones.
Car: check
Engine: check
Transmission: check
Use lots of oil while cutting (motor oil works), along with keeping the blade speed down. I take it you are using a Sazall or such? Get the bi-metal bldes as they will last longer. Will still need several to cut a bolt.
RBob.
RBob.
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
a few weeks ago when i swapped out my rear ends i had trouble with the panhard bar to axle bolt. i just unbolted it from the body instead and then used a torch and it spun off like butter
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Both my Camaros have been a pain when replacing any of the suspension and the panhard was just has hard as the rest. Ive been able too unthread the nut before but the bolt is frozen so a BFH helped then. Other times they just have too be cut then pounded out with a punch, if ur still using the stock bar. If your replacing with a aftermarket part id just cut it with a torch and get new hardware for the new piece saves alot of time. Beware of the LCA's if you change those too there a nightmare especially if ur bolts are frozen on the axle side. my 90 was frozen so bad that i had too remove the rearend and cut the lca into 3 pieces too remove it from the axle end lol.
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Spray PB blaster on it every two hours all day, than get a big breaker bar and someone to help you with a big adjustable wrench, its a bitch, but thats how i got mine off after 2 days of doing that.
Car: 91 Trans Am
I have the nut off but the bolt is still stuck so I might just cut the panhard rod so I can get the rear end out from underneath the car so things arent so difficult. I was planning on using the stock bar but this is such a pain that I dont want to deal with this again so I will just buy a new one.
Use a huge hammer and beat the crap out of it. You gotta load it up on the PB blaster while doing it. That happened to my body brace thing right above the panhard rod, got it stuck and couldnt get it to move, after wacking away at it for about an hour and cursing alot it finally moved, it helps to put a socket on one end and keep rotating it while hitting it from the other side, grab a friend and go to town on that sucker.
Car: 87 IROC
Engine: 5.7 TPI
i am having this same problem. what a bitch to get the bolt out. i broke mine off at the nut side. i cant get straight shot on the bolt to beat it out w/ the rotor in the way. i may need to cut the blot head off and beat it out that way.
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Good to see Im not the oly one with this problem lol. Workin on my buddys car we finally got the nut off after a can of PB blaster. The bolt was stuck so we used a 5 lb sledge
u might have too remove the rotor i think the bolt might be too long and will hit the rotor if u try too pound it out the other way. Pray too god that it does pound out like i said i couldnt get mine too budge even after cutting off both sides. If i can help it i will never do a 3rd gen rearend again lol... both of mine that ive done putting them back in is a pain with one guy especially when the 10 bolt is laying on ur chest while ur trying too prop it in place with ur leg... lmao!
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I had the same exact problem you are having. If you got new bolts I just cut the old ones off with an angle grinder. Cut them off at the head so you can at least get some vicegrips on them. That is a last resort really.
Car: 1987 IROC-Z
Transmission: TH350
What if you try tightening it until it snaps off? I did that for a lower control arm bolt, then used a punch to hit it out... problem solved.
if its that easy.. mine was horrible it might have been a more then bad situation then most but when i did get mine off i looked at the metal sleeve inside it had rusted so bad in there that the bolt and the sleeve had basically became one.... a punch and i hammer had no chance of getting that out maybe a 8lb sledge... lol
Car: 91 Trans Am
Well I cut the bolts off on both ends but now I have to get a grinder of some kind to grind enough metal out so the panhard rod will just drop out.
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Well, all that is well and good. I was troubled with something like this a while back on a different car, but after about a half hour of beating with a hammer and torch, nothing.
Use an air hammer/chisel. Leave the nut on the very end of the bolt for more surface area. Spray it down with WD-40/PB blaster/etc. and hit it. Bolt dropped out within 15-20 seconds.
Car: 91 Trans Am
FINALLY! After cutting out the bolts I still had some metal to grind away so I picked up a grinder and what do you know the panhard rod dropped right out, what a relief that was. I also picked up a 255 walbro pump since I was removing the rear, so I started to take out the gas tank and what do I see? A BIG FREAKIN HOLE cut into the car since the previous owner was to lazy to drop the rear end to change the fuel pump.
So I ripped the carpet up to find that he put rivets into a sheet of plastic and also caulked it down. I would like to meet who ever did this just to ask him what the hell was he thinking. I might just have to weld some sheet metal back in there to make myself feel better.
So I ripped the carpet up to find that he put rivets into a sheet of plastic and also caulked it down. I would like to meet who ever did this just to ask him what the hell was he thinking. I might just have to weld some sheet metal back in there to make myself feel better. Thread
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
