4th Gen Steering column in a 3rd Gen ???
Old Aug 26, 2008 | 06:41 AM
Camaroal's Avatar
Car: 98 Camaro
Engine: 441ci LS7
Transmission: th350
Axle/Gears: 4:10's
4th gen column in a 3rd gen. Do you use all the stock 3rd gen stuff from the box to the column or are there special parts you need to bolt up the steering shaft to the 4th gen column
Thanks in advance
Old Oct 5, 2008 | 11:07 PM
screeminchicken's Avatar
Re: 4th Gen Steering column in a 3rd Gen ???
Just to give this threrad a bump........ can a 4th gen steering assamble (rack and pinion) replace the steering box on a 3rd gen.....
considering
I want to keep the 3rd gen steering wheel
and I will be using a Spohn LS1 swap K-member .......(is there a special order to add a rack and pinion setup to this)
Old Oct 6, 2008 | 12:43 AM
Oops....looks like after reading the suspension forum for 2 hrs ...........I finally found the answer.
Sorry to bring this hors back.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
