cheapest bolt on frame connectors
Old Sep 6, 2008 | 07:01 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok, i know weld in is better ,but i don't have any access to a welder and these shops charge too much. but i need to find the cheapest bolt- in sub frame connectors. i'm tired of the car twisting on launches ,and if i just want to put one side up on ramps it throws the hood out of whack.
Old Sep 6, 2008 | 09:48 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: cheapest bolt on frame connectors
You have a delima for sure. I think you may be wasting your money on bolt-on but I haven't tried them either. Maybe it's better than nothing. The convertable guy's can correct me here but I think there's a x-brance or other stifening plates used on the top down cars.
Here's a thread I did for making your own.
https://www.thirdgen.org/forums/susp...tors-pics.html
With the money you save you just might be able to afford time at a weld shop.
Old Sep 6, 2008 | 10:09 AM
Stephen's Avatar
Car: 87 GTA
Bolt on are better than nothing but....
Save a little money by grinding the weld places clean, bolt yours on, then take it to be welded. All they'd hafta do then is give it a quick wipe & weld.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
deracer
Apr 11, 2016 12:04 AM
Thornburg
Aug 27, 2015 11:34 PM
