I need advice....
Old Sep 8, 2008 | 11:21 AM
HottestZ28's Avatar
I need advice....
OK I did a MPFI to Carbed 350 swap and I ordered 1984 camaro non a/c v8 springs. Now when I installed them they are exactly the same position and I did reinstall the spring cup for noise. When I put the car on the ground it sat like 2 inches higher then it did before which was something I could deal with, but when I reinstalled the torque arm there is like 5 inches between the tire and the fender lip which now is killing me I will try to get pictures.
I just don't know any other way to go because I def didn't want the v6 springs and they are moog springs so they should be decent
it doesn't have the fenders, nose, radiator, batt, hood, f/seats, carpet, heater box. but will that stuff lower the car alot?
Old Sep 8, 2008 | 11:58 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: I need advice....
Has it rolled around on the new springs yet? Lifting it up and setting it down will cant the tires in and can cause the suspension to be jacked up until it rolls some to let the suspension settle.
The springs themselves will also settle a bit after driving it some, but you've likely just got the suspension in a bind the way the tires drop and set back down when lifting.
Old Sep 8, 2008 | 02:11 PM
HottestZ28's Avatar
yea I hope so this stage has been rough getting them in without the motor in and all
Old Sep 15, 2008 | 02:46 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Yea, u won't really know the true height till you've got it all together and drive for a few miles, then u could always take them out and trim slightly. Good luck.What model Moog spring are they. Later.
RS707
Dec 11, 2012 06:17 PM
SpeedRacer49
Mar 16, 2012 10:19 PM
555
Nov 17, 2009 09:07 AM
WILL85IROC
Jun 7, 2006 03:11 PM
ghilly24
Sep 15, 2005 11:28 PM
