1991 camaro drop top..i turn the key and nothing happens
Car: camaro rs drop top
Engine: v6
Transmission: auto
I just got the car and it has a new starter a new battary and a new altanater..also fuel injectors and all new gaskets...now he told me sometimes u have to mess with the tilt wheel for it to crank over (move it up and down) i dtove it all day yesturday and it was good i did not have to mess with nothing then this morning i went out to go for a nice ride and nothing i turn the key and it did not crank or make any sounds..it also has a new fuel pump and i hear that come on..please help is there any way i can fix this so i wobt have to worry about it anymore? Any ideas please and thanks for advice....
Engine: v6
Transmission: auto
Car: '91 Camaro RS
Engine: 3.1v6 stock
Re: 1991 camaro drop top..i turn the key and nothing happens
Like stated above it could be the anti-theft system. That stupid little chip in your key. I would definitely check your grounds and wiring though.
There is also a sort of 'junction' where a lot of ignition and starter wires connect. It is located in the engine compartment behind the passenger side headlight. Look there, close to the radiator. You might have to take your air filter can out to see it. Held in by two small bolts. I would check the connections on that.
If it is the VATS I'm sorry but I have no advice. All I know is that there have been times I blamed that stupid little chip in the key, and that wasn't the problem at all.
Car: 92 Z28
Engine: Boosted LSX
Sounds like its the 2 wires to the vats module that are broke. (Been there done that) Its a common problem on GM cars.
Heres some info I posted for someone else also..
Looks at your security light when you turn the key on to the run position.
IF the light is staying on Its prob. a vats issue.
Easy way to test that is to measure the resistance of your key.
get a inline resistor the same ohm your key is.
Then under the dash unplug the vats connector. Loop the resistor inline and see if it starts. / light goes out.
Two good links to tell you what Im talking ya thru to do.
https://www.thirdgen.org/vats_passkey_system
here
http://shbox.com/1/air_bag_disc_2.jpg
here
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
It gets the blame for all sort of problems ; global warming , high taxes ..........
Be great full you have it.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 92 Z28
Engine: Boosted LSX
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
