Sanding my wheels
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Sanding my wheels
I have an 86 Trans am with the stock 16 inch wheels. The face of them is pretty much flat with about a 3/4 lip around the out side, my question is can I use a palm sander to get the clear coat of then polish them up or will I have to do it by hand. I don't want to put a stripper on them because the black inside the fins and everything is perfect and it would take me forever to tape them off and even then there's a chance of it bleeding through the tape.
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Re: Sanding my wheels
A palm sander may work, just don't apply much pressure, u don't want to dig in cause when u polish them it would be real noticable. I would just do it by hand with wet/dry sandpaper u could control it better by hand, just use maybe 400, 600 then 1200 or so. Later.
Just tape them off as normal, chances are there will be some bleed thru. To take care of that just put some lacquer thinner on a rag and run along the edges after you peel the tape.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
The best way to do this (and yes I've done this a dozen times) Is tape off the tires so you don't get any on the tires and get a can of air craft paint stripper from walmart. It's in a blue can. that stuff works great. it will make it easier by far.
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
X2 on the Aircraft Sripper. Just be sure to do it outside. A pressure sprayer helps a ton to get the loosened paint off as well.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
well if i understand the question, he wants to keep the paint and sand the front face of the spokes...
mothers billet polish is your friend.
i used it, it worked.
i didnt worry about the clear coat either.
just follow the directions.
Also do the wheels have dimples or not? If they have the dimples then you'll be in good shape, the clear comes off VERY easily with the stripper. If you have the non-dimpled wheels then you're going to have one hell of a problem getting the clear off. For some reason it's damn near bulletproof
Car: 85 Camaro IROC
Engine: 5.7 TPI
like i said.
i didnt worry about the clear coat.
maybe mine was so worn that it was nearly non existant, but mothers cleaned it up.
wax on wax off.
thats all i did
wax on wax off.
thats all i did
Car: 1991 Z28 Convertible
Transmission: 5 Speed
I used a die grinder with surface refinishing pads, they come in many different grits and one can be very precise with them. Harbor freight carries them as do most body and paint supply stores. If you are going to polish the aluminum then you will need to remove the mill marks and get them as smooth as possible, these will help. Once you get them smooth you can use any sort of medium cut compound and a rag or a buffer. Finish up with a buffing compound and you will see them shine like chrome.
Hotrodboba400
Dec 10, 2019 07:07 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
