A couple wheel questions
What brands make a 16x4 or 16x5 rim for a 5x4.75 bc? Do any tire manufacturers make a front 16" skinnie tire that could fit those rims? And finally, does anyone make a 16x11 or 16x12 rim (maybe matching to the front)? Sorry for so many questions I'm just curious. thanks in advance.
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Re: A couple wheel questions
Well there is always Boze they make the rims to the specifications you want. But theres alot more to buying rims than most think. Like backspacing,offset,brake clearance etc. So try doing some research yourself, the search function should get you plenty of info.
V
