Bent Front end links?
Old Sep 27, 2008 | 12:21 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Hey Everyone.
Got my iroc put away for now, and i took my sway bar end links off while i was pulling the springs to paint & re-set them into the car & i found (atleast the driverside) end link was bent.
They werent bent before this year, drove the car about 1500miles this summer w/ the new motor.
I think my alignment was a bit out, would that cause it to bend? I just want to be sure that i dont have anything bad going on.
Its Eibach lowering springs, LS1 brake system & 1.5" Wheel spacers.
All input greatly appreciated.
Sheldon
Old Sep 27, 2008 | 12:48 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Bent Front end links?
Hey Sheldon, the alignment out of whack did not cause the end link to bend. Prob hit a pothole or something, which may have caused the alignment to go out of whack, and bent the endlink. Anyways, I would get the Energy Suspension or the TRW heavy duty end links. TRW makes 2 different endlinks, if you get them, make sure you get the heavy duty ones and not the regular ones.
Old Sep 30, 2008 | 09:08 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Let me guess . . . you have poly-bushed endlinks. And that you made sure that the endlink fasteners were "good and tight" when you installed them.
About the only thing that bends (and sometimes breaks) endlinks is clamping them too rigidly to the bar and the LCA. The LCA moves in one arc, the bar end moves in a different arc, and the endlink sort of wobbles along between the two. Too tight adds bending resistance at the endlink ends, and the endlink will lose every single argument with the bar about who is going to bend the most. One instance involving extreme suspension movement might only bend an overtightened endlink enough that it stays bent. Continued large suspension movements will eventually break one endlink by reason of fatigue.
Norm
Old Sep 30, 2008 | 09:44 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I did that. Haha. Just on the rear not the front.
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
