Hotchkis strut tower brace
Car: GM
Engine: v8
Transmission: slushboxes
Where did everyone drill the holes for this brace and how did you hold the bottom screw to the nut on top? Yes, I'm new to suspension but searching didn't bring any good results.
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Re: Hotchkis strut tower brace
I would go with the edelbrock 3 point strut tower brace. I dont know if the hotckis is 2 point or 3 point. But I have the edelbrock piece on my car, it tightened the front end up real nice. and the bolts on the edelbrock go through the body and the nuts go underneath in the wheel well.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I've been wanting to get a Edelbrock piece, but I'm not sure how it would mount with my strut mounts.
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Uh, I think he asked for directions, if I remember correctly, he bought the hotchkis off a board member. It didn't come with the instructions and I don't think he got the PM's I sent to him. Anyone have any ideas?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
installing one of these things is not rocket science. Assemble it, place it on the car, make sure its centered side to side and front to back on the open area of the shock tower, keeping as far forward on the shock tower as you can so it does not interfere with the adjusting of the upper strut mounts (the black thing). Make the holes, remove the bar, drill the holes, bolt the bar back on. I would assume there are bolts and nuts holding this bar on? i personally like to put the head of the bolt in the wheel well and install the nut up to, just so there is nothing sticking down into the wheel well that could possibly get into the tire in case of bottoming out or some kind of failure
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
It may not look as good this way but I would feel much better knowing it wont tear anything apart.
Mike
PS - If anyone has one of the Edelbrock TPI STB or other brand that they are wanting to sell, send me a message. I'm looking for a decent used one.
Car: 1991 RS Hardtop
Axle/Gears: 3:23
Thanks!
Car: 1987 Firebird
Engine: 355
I also just purchased a STB off a board member and it as well did not come with instructions. When you say 'keeping it as far forward on the shock tower as you can' ... does that mean, forward as in closer to the firewall, or closer to the headlights. I know this may sound like a dumb question, but i've heard it spoken of in both ways. I assume you mean closer to the headlights, but i want to verify. With that said, the shock tower is inclined towards the 'headlights' front of the car, so I worry about clearance issues with the hood opposed to pushing it closer to the upper strut mounts. Any feed back would be great!!
Thanks!
Thanks!
Since the bars are usually mounted in front of the strut towers, i will assum closer to the headlights. This will still allow you to adjust the strut mounts, back and forth or whatever. You just want some space between the STB mounts, and the stut mounts.
LT1Formula
Oct 8, 2015 08:34 PM
tcflint
Sep 27, 2015 05:58 PM
