lakewood trailing arms
Old Oct 9, 2008 | 05:05 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
anyone use them or have any feed back? they are around 100.00 at jegs and summit so i thought i might get them and they have poly bushings also that would be an upgrade over the stock arms.
Old Oct 9, 2008 | 05:51 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: lakewood trailing arms
UMI is doing another group purchase, get in while you can!!!!! 15% off!!!!!
https://www.thirdgen.org/forums/grou...ml#post3910809
http://www.umiperformance.com/produc...ategory_id=106
Nothing agaisnt the Lakewoods, but UMI is a sight sponsor, and they make top quality pieces
Old Oct 9, 2008 | 06:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
lake wood arms are a good upgrade over stock. People have there opinions on poly bushings and binding, but they are a good piece none-the-less.
I will second Kris, check out the GP, its just starting and should happen. UMI's parts are very top quality and you can save a few bucks with the GP, maybe splurge on some other parts too.
I would recommend a control arm with poly bushings on 1 side and a rod end of some kind on the other, to help eliminate some bind.
Old Oct 11, 2008 | 08:36 AM
deadman's Avatar
Car: 89 camaro
i went with the umi parts and they should be at my house tuesday, the best part is they are only about an hour drive from my house . as for binding i was told i shouldnt have a problem unless im pushing the car to its limits on a road course so i should be fine.
Old Oct 11, 2008 | 09:20 AM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I have the Lakewoods on mine, and have had no problems at all.
Old Oct 11, 2008 | 03:05 PM
deadman's Avatar
Car: 89 camaro
im very happy to report that yesterday at 10 am i order the trailing arms from umi and they were at my door at 10 am today , i put them on with a new set of coil springs and no more wheel hop and its alot stiffer. im a very pleased customer!
Old Oct 11, 2008 | 05:13 PM
krisb410's Avatar
Yea, UMI does it again
Old Oct 13, 2008 | 01:35 PM
UMI Performance's Avatar
Excellent to hear
Thanks for the business!
Ryan
Old Oct 13, 2008 | 10:22 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I must push mine to the limits too much. I got my car to do it so much on on-ramps, I could predict when it was going to happen. It's not a fun experience. That's why I built my current LCAs. Much better all around, IMO - ride, noise, handling performance.
No offence to UMI's product, or anyone elses, it's just the nature of putting a bushing in a location in which the bushing is too stiff to allow the suspensnion to operate the way it's designed to.
Old Oct 14, 2008 | 03:23 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Here's some Spohns, also a board sponsor.
Getting ready to weld in the Sub Frame Connectors
also Spohn. Also running thier relocation brackets, adjustable torque arm and track bar. Poly to frame and Hiem to suspension, noise cushion.
Poly front and Hiem rear, keeps the ajustability in
play if needed.
Later
Old Oct 14, 2008 | 04:38 PM
krisb410's Avatar
jaykar: Your a day late and a dollar short. Deadman has alread purchased LCAs.
On another note: I used to live out there in Prescott for 5 years, lived in PV for a summer. Have to say, I loved the scenery, but besides that, not much to do.
Old Oct 15, 2008 | 01:26 PM
jaykar's Avatar
As to this part of the country, Yes it is nice.
70 and clear today and going to take the Roc up in
the mountains today and clear it out a little.
Older generation, so not much to do here just fine
with us
T-tops off and 500+ Hp under the hood is plenty to
do here.
Going to datalog, take pictures and get ready for next
step, Two stage NOS-Carefully!
75 or 100 at 60ft and 150 at 1/8.
Big problem down low on motor as to traction now, Even
with all the good suspension pieces in place.
Later
Old Oct 15, 2008 | 02:40 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I really like the color of the control arms and PHB on your car. Not seen that before.
Old Oct 15, 2008 | 03:12 PM
jaykar's Avatar
Thanks,
One of the reasons along with the quality was he went
to the extra trouble to powdercoat all the pieces to match
the gold Iroc trim on the car.
At no extra charge.
Another pic.
Later
Old Oct 17, 2008 | 07:16 PM
deadman's Avatar
Car: 89 camaro
i also bought the panhard bar and installed it today .... its a good piece also.
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
