Harness Mount Idea
Old Oct 12, 2008 | 01:44 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Harness Mount Idea
I've been reading a few roll cage threads, and I also would like to have a 4 or 5 point harness. However I would still like to have somewhat easy access to the rear seats because it will be my daily driver and I sometimes am forced to take more than one passenger.
Here are some of the reasons I thought of this:
1. I infer that this is safer than mounting the harness to the floor, since in case of a wreck the harness will not compress my spine.
2. I dont think it would look too dumb by using the top since there isnt much lenght from the top of the car to the seat (maybe 4 to 6 inches will be visible)
3. The belts would go through the "holes" in the seats, so your shoulders will still be in place as if there were a bar across the cage.
4. By doing this I keep the ability to recline my seats and have access to the rear seats (even though the space back there is minimal I still would like to have that luxury)
Below are a couple sketches that I made regarding my idea of using the top of the roll cage as mounting points for the harness...
Here's my question; Would this be remotely safe or am I completely out of my mind for even thinking about this?
Roll cage and harness
Side view of seat and harness
This is obviously still in its planning stages so I'd like to use some of you guys' knowledge to either improve the design or scrap it..keep in mind Im an inexperienced 16 yr old so please dont flame my idea
Thanks,
Fernando
Old Oct 12, 2008 | 02:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Harness Mount Idea
You're not going to be able to recline the seat with that setup.
Do you need a cage and harness?
Old Oct 12, 2008 | 03:08 PM
I should be able to recline it because of the absence of the horizontal bar that goes across the cage..right?
yea I dont need a cage with my 305 but Im going the LS1 route and I want to have a stronger chassis(more than what you can get from SFC's) along with protection when Im auto-xing
(maybe I posted this thread too soon, since Im not going to be able to actually do this for quite a while(next summer) but I just really like planning mods to the maro )...
Old Oct 12, 2008 | 03:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Won't pass a tech inspection as per NHRA/IHRA installation specifications.
You can do whatever you want on the street.
Old Oct 12, 2008 | 03:30 PM
Ahh I see...thanks for the info..
would this be safe though?
Old Oct 12, 2008 | 03:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, the upper straps are going to keep you from reclining the seat.
It won't be unsafe, just kind of pointless.
Old Oct 12, 2008 | 03:46 PM
Ohh..dang it
I guess horizontal bar across is kinda the only way to have a harness then
but wait..if the belts are adjustable wouldnt that allow you to make some slack therefore freeing the seat when you want to recline it?...
Old Oct 12, 2008 | 04:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Having slack in the belt totally defeats the purpose of having the harness in the first place.
Old Oct 12, 2008 | 04:20 PM
lol yea I know that..I meant that when parked and without the harness being engaged I could then recline the seat..I dont want to drive with the seats reclined..I just want to be able to recline the seats(something you cant do with the horizontal bar..I think)
Old Oct 12, 2008 | 05:15 PM
Stephen's Avatar
Car: 87 GTA
Mounting the belts that way will keep you back (somewhat) but not down.
Might as well just not pass the through the seat & drop them forward over the seat. Doing it that way, not only will they be of little use, but you'd fit right in, in an import r i c e r crowd.
You could always make the standard shoulder harness bar removable, like the swing-out door bars. Very doubtful it would pass a track inspection, but it would still work better than coming from way up top, on the main hoop.
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
TheJoeY88
Dec 31, 2016 07:30 PM
jharrison5
Aug 19, 2015 05:53 PM
stalkier
Aug 13, 2015 12:59 PM
