Edelbrock TBI Strut Tower Brace
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
Will the Edelbrock strut tower brace for TBI cars work in a V6 with a 4-bbl carb setup?
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
Re: Edelbrock TBI Strut Tower Brace
Not sure, but I like the Edelbrock one the best because it is square tube instead of round... looks better... I believe its 3 point also...
BUT, if not sure just get a TDS Wonderbar... supposedly better than STB, and easy to put in...
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it should , but there is an age problem . #5226 fits 87-92 tbi , its round . # 5227 for tpi with small mods should fit any year , its square . i have had both , i think the #s are correct . i may have them reversed ???
Car: 1984 Camaro
Engine: 327
I checked out www.edelbrock.com and the 5227 is for TBI or carb V8's.
I also went out to the car and taped a line between the fenders that passed over the forward inboard studs of the upper strut mount. The line passed right over the rear edge of the alternator, right over the top of the a/c compressor, and over the snout of the V6's stock air cleaner snorkel.
Based on the picture of the 5227, the configuration is unsuitable for use on a V6. I would have to shorten my alternator, bore a hole through the compressor, and cut the snout off the snorkel and weld it back on upside down. I think it would be easier to install my little 327 instead.
I shall consider the Wonder Bar idea as an alternative. I've seen pictures of the thing and I'm still trying to figure out how it works. It looks simple enough to fabricate at the hangar.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Here is a pic of mine. They don't reinforce the area around the strut towers, but it's a good idea if you run 16s or bigger... I'm pretty sure it's a good idea on any of these cars lol. I have the wonder bar, and I'm planning to get a Edlebrock STB as well.
The Edelbrock 3-pt. can be seen in my Car Details below.
JamesC
JamesC
Car: 1987 Firebird
Engine: 355
id have to agree with OP.
Just by "eye-ing" it, you can see that the pulleys of the accessories are pretty much in line with the front of the inner fenders towards the top. ie: if you held a wooden beam from side to side along the top of the inner fenders (where the strut towers mount) it will hit the pulleys on a V6 engine. See pic.
http://www.fernfactorypictures.com/c...o_engine_m.jpg
Conversely, if you look at the posted pic above, the strut tower brace on the picture posted above, the strut brace follows a strikingly similar pattern. I would second the notion that it will interfere.
However, if you are able to modify it, i dont think it would be too much trouble to move the front of the brace forwards a couple of inches. Or heck, even make a new brace yourself. Shouldnt be too hard.
Car: 1991 RS Camaro
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Car: 1984 Camaro
Engine: 327
Great pic from 91 Camaro. I think the bar would clear the V6 compressor and alternator if it was mounted upside down and the firewall bracket was relocated.
Then it would hit the bottom of the hood for sure!
But if I built or bought an IMSA style hood like Dingman Bros. used on their Firebirds, it would clear. This wouldn't be such a bad idea styling-wise since my car already has IMSA style fenders.
But then it would be a paper tiger with the little V6 under such a ferocious exterior. So it would make more sense to install one of my mouse motors so the car would walk the walk as well as talk the talk.
Then I would not have to mount the bar upside down or modify it.
Yadda-yadda-yadda!!! This is a typical never-ending hot rodder story. Haha!
I would like to thank everybody for their input. I am no closer to a solution but my brain is now more crowded with ideas, which I like. Being a realist, I realize one of the solutions is no solution at all, i.e. no STB.
Maybe UMI's STB will work
Engine: LB9 & L98
The Wonderbar is a GM BandAid introduced to strengthen the steering box area of IROC's and their 16" wheels. It wasn't then the performance part that it seems to have become in recent years. Most drivers, in a blind test, wouldn't know if the Wonderbar were installed or not. Still, it's a good preventive.
JamesC
JamesC
Car: 1984 Camaro
Engine: 327
To krisb410 :
Thanks for that pic! That UMI bar certainly looks like it'll work. Who supplied the unit?
UMI, they are having a group Purchase right now!
Car: 1984 Camaro
Engine: 327
I'm not ready to participate in a group buy right now. Is there a website where I can view UMI's various products? I've Googled them and got no hits.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 1984 Camaro
Engine: 327
Thanks for the URL, 86TA! Greatly appreciated! UMI's webmaster needs to do something to improve results for potential customers. Perhaps I will drop them a note to this effect.
Car: 1984 Camaro
Engine: 327
IIRC, the Edelbrock blurb specifically stated that it would not work with the dual snorkel.
Car: 1984 Camaro
Engine: 327
Yup! Here it is; cut and pasted from www.edelbrock.com:
1982-92 Camaro/Firebird V8 with Throttle Body Injection or carburetor (fits vehicles with A/C compressor on passenger side, will not fit dual snorkel air cleaner) #5227
Car: 88' Iroc-Z
Engine: LQ9
i believe i read that it had something to do with the firebirds underhood bracing. im not 100% on that ive never dealt with firebirds.
Car: 1989 Firebird Formula 350
Engine: 350 TPI L98
Axle/Gears: 3.91
thanks but what i dont get is it will work for the firebird coupe and trans am but not the forumlas which is weird cause their not that different in construction at least i think
Car: 88' Iroc-Z
Engine: LQ9
i dont really know either, the formula has the raised part on one side and the TA or firebird doesnt right? i've read many people modifying the pieces that mount to the strut towers because they are thin and flex
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Anyone know if these are bolt on, or need to be welded in?
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Car: 1984 Camaro
Engine: 327
Four years after I started this thread I finally have a QA1 (formerly Edelbrock) 5227 STB mocked up in the car.
In order to get the brackets to sit flush on top of the strut towers, the stock shock mounts are almost all the way inboard and all the way back, making for lots of negative camber and positive caster. There is very little room for adjustment.
Descriptions of various aftermarket caster/camber plates tout additional caster adjustment so maybe maximum caster with stock shock mounts is not such a bad thing. Lots of negative camber might be good for a track car but mine will be primarily a street machine.
Has anyone trimmed their stock shock mounts to allow for more adjustments with the 5227's brackets installed?
In order for my Founders strut mounts to fit (with the Edelbrock already installed), the Founders base plate required trimming.
JamesC
JamesC
Car: 1984 Camaro
Engine: 327
The bores in the strut tower ends of the QA1 5227 STB are 12 mm or a hair over 29/64" i.d. The bolts supplied in the kit are 3/8" and so are the slots in the strut tower brackets. That makes for an awful lot of wiggle room in a device designed to maximize rigidity.
Should I:
a. install 3/8" i.d. bushings in the bores to eliminate play?
b. use 12 mm bolts and either modify the supplied brackets or fabricate new brackets?
c. install the brace with the supplied hardware and oversize bores?
Should I:
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I came across the problem of the STB limiting the possible position of my aftermarket founders strut mounts too. I refused to grind the strut mount, so instead I notched the STB bracket and then welded another piece of steel to the bracket on the inside to ort of box it in and add strength. Then I just cut a rectangular piece of steel and installed it under the bracket in the wheel well to add more support. Overkill, but I feel better now.
Car: 1984 Camaro
Engine: 327
Based on the paint patterns left behind on top of the strut towers after removing the strut mounts, maintaining the previous caster setting will not be a problem with the stock brackets. However, the brackets do limit camber adjustment. I intend to trim the brackets as much as possible and the strut mounts as little as possible in order to allow a decent amount of adjustment.
My concern now is that the bolts supplied have way too much play in the bores of the strut tower ends of the brace. The simplest solution I've come up with is to bush the bores so I have a nice close fit for the 3/8" bolts they supplied. I'm also considering upping the bolt size to 10 mm for the sake of metric uniformity.
Car: 1991 Z28 Vert
Posting some pics of what I did with the Strut tower brace' brackets. I ended up making my own out of thicker steel and welded in a plate on the front. Then Cut out a small portion to clear the strut tower in all possible directions. The bracket is very strong even with the metal remove for clearance. I even did one bracket where I just welded in the front metal for support and that was probably plenty.
Car: 1984 Camaro
Engine: 327
Thanks for posting the pics, Tibo. I had a similar idea and all inputs are welcome.
toronto formula
Sep 10, 2015 07:31 AM
