Progressive Rate Front Spring Install
Old Oct 26, 2008 | 03:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Simple question but I have not found the answer to a yet and am still searching...
When installing progressive rate springs that are more tightly wound on one end of the spring which way goes up????
Old Oct 26, 2008 | 05:17 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Re: Progressive Rate Front Spring Install
On a thirdgen there's really only one way that the front springs will go in properly. They are matched to the pocket and must be indexed to the drain holes.
Old Oct 26, 2008 | 05:35 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
As far as indexing them yes, but both the respective top and bottom of the spring is uneven and can be indexed. I'm pretty sure I figured it out; the tighter wound part on the bottom...
At least it makes sense since that would be the stiffer portion. Plus, the manufacturer name would be right side up this way (not that this really means anything).
Old Oct 26, 2008 | 05:43 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
On my Eibachs the top is flat and the bottom has the pigtail.
Old Oct 26, 2008 | 07:50 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Are they progressive rate? If so, do you happen to remember where the tightly coiled end went?
Mine are cheap Intrax springs and neither of the ends are level, however, the tightly coiled end is slightly more level than the other.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
