Anyone space IROC wheels outwards to fill wheelwell?
Old Oct 13, 2008 | 10:27 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I'm wondering if my double stripe 88 IROC wheels would look better if they were moved/pushed closer to the outer edge of the rear wheel-wells.
Has anyone used wheel spacers with these 16 inch wheels with any success? I really like these factory wheels but wouldn't mind a bit more of an aggresive stance.
Nitro-Nicky
Old Oct 26, 2008 | 12:27 AM
86irocterror's Avatar
Re: Anyone space IROC wheels outwards to fill wheelwell?
when i had my stock wheels on my 86 iroc i had used 2 of the factory wheel spacers on each side from the drum brake rear irocs and it moved them out i think 1/4 inch. not real drastic but in not a big fan of wheel spacers. i just got aftermarket wheels. i wish someone would make an aftermarket iroc replica in a 9"or 10"wide
Old Oct 26, 2008 | 12:37 AM
Stephen's Avatar
Car: 87 GTA
You could always just get another pair of front offset wheels for the rear. They'll fit great & look good.
I used to run 4 front offset GTA crosslace wheels (until I got my Snypers) & LOVED the way the rear wheels set out farther.
Old Oct 26, 2008 | 01:24 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
i was just about to post that he could use another set of fronts instead of spacers!!! ha
Old Oct 26, 2008 | 07:55 PM
neagan's Avatar
Wow! Does the rear tire still fit in under the fender lip? I installed the 1/4 inchers up front this past week and found a mag wheel lug nut that has a nice and narrow shank so it slides right in on the old studs.
My IROC does have factory rear discs and I'd be elated if I didn't have to use spacers. They make me nervous about doing high speed runs across the desert should they get a little loose and move the balance point. I suppose I should take these new front shims and have them tacked to the front mags for safety and final wheel balancing.
Might any of you have a pic that shows how tight the spacing ends up being? That would also be killer if I could then start rotating my directional tyres!!!! I really appreciate you guys chipping in your comments on this. big thanks, Nitro
Old Oct 26, 2008 | 08:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
ran ls1 4th gen rear on mine. spaced the wheels out nicely...but just a touch past the fender lip
i think with a 1-1.25 inch bolt on spacer, it will be perfect as the 4th gen rear is almost 2 inch per side
Old Oct 26, 2008 | 08:20 PM
neagan's Avatar
That looks MUCH better! My front tyres now look the right size for the opening and the rears lack any aggresiveness character.
Old Oct 26, 2008 | 08:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah i loved the look and should have matched the front. the rears actually were alittle further out than i wanted but ppl did like it. i got compliments surprisingly
BlueIroc-Z
Jun 9, 2019 03:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
