Question about BMR coil over conversion kits
Car: 92 camaro Z28
Has anybody tried a lighter springs for this kit. I have the BMR coil over conversion and a-arms but the front end still sits to high with the adjustment all the way down and i would like to drop it at least an inch more in the front.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Question about BMR coil over conversion kits
what height springs are you using?
Car: 92 camaro Z28
The kit came with 10" long springs rated at 200 pounds and that is what I have been using for the last couple of years
Car: 86 Trans Am
im using Spohns kit, with a 12" spring rated at 325 lbs, i have the car sitting at a good height, and im still at the middle of the adjuster.
If you lowers your spring rate, you will probably start to have a very bouncy front end and may even bottom out the springs and start warping the fenders
have a pic of you car form the side?
Car: 92 camaro Z28
No pictures of the side of the car lately but when I get it out of the trailer I will try to get some
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
