Lowering 101
Old Jan 13, 2012 | 06:44 PM
  #51
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: Lowering 101
Originally Posted by potterc32
I am wondering about the adjustable torque arm and front alignment. I can handle the LCARBS and panhard bar and springs. But are the torque arms really necessary? I don't do much racing, just a little hot roddin here and there. Is pinion angle going to effect my car much as a daily driver and not a race car?
And I'm with the last guy, wouldn't a good alignment take car of the camber issues up front?
I want to use factory style shocks/struts.
I would be using the Eibach pro series-- 1.6 in front, and 1.3 inches lower in rear
-I think you'd want to worry about correct pinion angle more with a daily driver because it will cause noise under loads and possibly premature bearing failure. With a race car you are setting it to compensate for axle windup.
-You have a limited amount of camber that you can adjust to make up for the lowering springs. You should be okay with the pro series. I've had my car up on the rack after I put in the eibach pro kit and was able to put camber, caster, and toe within spec.
Old Apr 15, 2012 | 10:50 AM
  #52
91slpz's Avatar
Car: 1991 SLP Z28, 1972 GTO, 1976 Camaro
Engine: 350tpi, 396bbc, 427bbc
Transmission: 700r4, th400, 200r4
Axle/Gears: 3:42, 4:56, 3:08
Re: Lowering 101
i was wondering if there is a thread on how to install the bags on a 3rd gen fbody. if anyone out here can tell me what they used to mount the bags on the frame rails and how they did it that would be awsome as i have a bag kit i got off my brother. it was his spare set up from his s10 he ended up not using. any help would be appreciated. i was thinking using bolt in bag cups would be easiest just have to drill a hole through the sub frame. let me know what you guys think. thanks for the help
Old Apr 15, 2012 | 11:39 AM
  #53
91slpz's Avatar
Re: Lowering 101
nevermind i finally found the info i was looking for and the only thing i could use from this set up is the air management.
Old May 7, 2012 | 11:03 PM
  #54
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Lowering 101
If i buy the hotchkis handling kit do i have to use the provided springs?
Old May 9, 2012 | 04:59 PM
  #55
Mr Froman's Avatar
Re: Lowering 101
I don't think it is necessary. I believe the lowered springs are just provided to improve handling.
Old May 9, 2012 | 06:27 PM
  #56
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Lowering 101
K cuz from the way ppl talk about it, it sounds like lowering is just a pain in the keister.
Old Sep 20, 2012 | 08:15 AM
  #57
Ryan3834me's Avatar
Car: 88 TA
Engine: 383
Axle/Gears: 2.77
Re: Lowering 101
If Sportlines aren't a racing spring, you've lost me! They are one of the highest rates you can find, and barely friendly to even Konis. Can you cite this dialog with Eibach?
Old Nov 17, 2012 | 09:48 AM
  #58
dgrejtest's Avatar
Re: Lowering 101
Hi,
I've been searching the board, but didn't find the answer...
Anybody tried to fit Vogtlands or Eibachs on V6?
Previous owner of my car cut original springs too much, so when I lift the car, they fall out (well, allmost).
I'm from Europe, so it's hard to get any springs, even stock... :S Only Vogtlands are on german ebay... The shipping from US costs more than springs...
Any advice?
Old Nov 19, 2012 | 11:27 AM
  #59
Ryan3834me's Avatar
Car: 88 TA
Engine: 383
Axle/Gears: 2.77
Re: Lowering 101
Your V6 car is identical in every way to V8 car. The only change would be the stance.
I've not heard of anyone putting the 'sport' spring or struts on a v6 car. Maybe try a Turbo Trans Am site (1989 TTA). The ride of sport spring and sport lines is quite stiff! But controlled. You may be in for a shock if you go with them. Factory V6 setup is soft compared to stock WS6. If I were you... Maybe consider the 'touring' spring and shock setup from Eibach and Koni and cut fronts for stance.
If you do lower, you should strongly consider Adujustable tie rod ends. You can raise the pivot point on the spindle with them to help bumpsteer.
Old Nov 19, 2012 | 11:50 AM
  #60
dgrejtest's Avatar
Re: Lowering 101
Thanks for the answer.
I've had hard suspension on my cars... so I know what is hard... But this... I'd say it has no suspesion (well, maybe 1,5 inches). The front is so fu**ed up, that the tire rubs on the inner fender (i don't know the exact english word for it) - and yes, the plastic fenders were allready taken out..
After searching the board I think i'll try Vogtland's as they are the only available/affordable option... And we'll see from there.
Stance is secondary problem right now. I'd like some more drivability first.
I'll report.
Old Feb 12, 2013 | 05:54 PM
  #61
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Lowering 101
I've spent alot of time reading the suspension board and reading the search result threads that come up about eibach springs as those were my first choice and i couldn't decide between the pro-kit and sport lines. So many mixed opinions (although all very creditable) I was less sure than when i started(and ended up researching lots of brands) Of the eibach people it seems that those with the pro-kit all love the ride but the complaints are "its not low enough", or "I didn't even notice a difference". and some pics IMHO supported these statements. The sport line people are a mixed crowd, they either love them or hate them. the complaints i read were mostly about them being too low, or too soft in the rear or "kept hitting the bump stops". I called eibach and got the spring rates (they are on here but sometimes its best for me to hear it from the source).Here is what they gave me.
Prokit front:714 linear, Rear 109-177 progressive
Sportline front:700 linear, Rear: 80-137 progressive
So trying to stick just to eibach springs here, the question i would like to propose to ya'll is; If your going to use eibachs wouldn't the best option be to buy the prokit and cut them down to get a lower ride height as that would keep the spring rates up and and eliminate (or at least improve) the usual complaints about the sport lines?
Because I REALLY like to autoX my nice weather cruiser i didn't get the eibachs cause of this dilemma and the progressive rear springs. It took me a several weeks of debating and researching several brands, and considering several different combos from MOOG IROC springs cut down to mixing and matching eibach fronts with Global west S40 rears (190 lb linear) to finally break down and spend the big bucks for ground control weight jacks. They were everything i was looking for (except the price), all linear springs, spring rates i want, and any ride height i want.
I don't claim to have any expertise i just wanted to share my experience so that hopefully it may help somebody else. The "best" springs depends on what purpose you car serves for you. Eibach is a quality product and may be perfect for your 3rd gen. If you ask ten people on here what "the best springs are" you'll get ten different answers.
PS I did look into coil overs and between the fact that that part of the car wasn't made to support the weight and the fact it prevents wider wheels/tires, I decided against them very quickly for my build.
Old Mar 26, 2013 | 05:46 PM
  #62
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
Re: Lowering 101
So plum92_camaro, did the ground control weight jacks you went with require the struts that they ask about when you go tovthe website? I was considering the weight jacks as well but saw that they asked about shocks and struts that cost $750+ alone and that kinda made me shy away from them. What is your set up of? You seem happy with what you've got lol
Old Mar 26, 2013 | 10:52 PM
  #63
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Re: Lowering 101
If you're going to run the weight jacks you'll want to upgrade your struts and strut mounts to spherical bearing, raised mounts and good quality adjustable struts/shock. Stock or old struts and shocks are junk by now and should be replaced immediately regardless of the car's ride height or intended purpose.
With the weight jacks, el grande cheapo struts and shocks don't do a good job of dampening with a high spring rate and wear out quickly, especially if the car is cranked down to sit low.
Weight jacks don't really "require" any special strut or strut mount per say, as they fit in exactly like the factory springs, but I wouldn't run them without decent condition struts/ shocks period and I wouldn't do anything radical with the height or spring rate without using high quality dampers like Tokico Illuminas, Koni Reds/ Yellows, or KYB AGX's... which is the main purpose of getting them. The weight jacks in themselves are pricey so the only way they're really justified is if you're tuning the car carefully for top notch handling or if you're going to run a crazy stance, both of which require good struts and shocks. Otherwise, skip it, buy the best quality dampers your budget will allow and some off the shelf drop springs and call it a day.
Old Mar 26, 2013 | 11:01 PM
  #64
Car: 92 Camaro RS
Re: Lowering 101
way better answer than what i was gonna say.
Well i'm defintitely excited about my set up but i don't know how happy i am yet because i haven't installed anything yet due to the longer than normal iowa winter. Like i said i'm no expert but i did a lot of reading to select my parts and i'm continuing to read to learn to set them up properly.
Old Mar 27, 2013 | 11:09 AM
  #65
TKR 88 GTA's Avatar
Engine: HSR 350
Re: Lowering 101
Thanks midnightfire! A lot of good info and I guess that just steered me away from the weight jacks. My car is a daily driver for the most part and as of right now the car is sitting with its left side sitting a good amount lower than the right side plus the front is higher than the rear because of the new engine set up that lightened up the front end a good amount. So I definitely need new shocks/struts and springs. But I didnt want to lower my car at the same time which got me interested in the weight jacks but im not gonna use the car for any hair pin turning or anything like that just a street and probly strip time once a month. So in that case ill probly just go with an eibach set up with idk what struts and shocks yet lol
And plum92 I feel ya on the longer than normal winter over here in colorado its ridiculous, snow was suppose to stop and then we ended up getting 8" this past weekend lol ive been wanting to do some stuff but nope lol
Old Mar 27, 2013 | 04:24 PM
  #66
Engine: LG4
Re: Lowering 101
Yeah the Eibach springs are great! Probably the most popular choices and most people seem to like them. Like I said, shoot for the best shocks and struts you can afford since you usually get what you pay for there. I was dead set on Koni so I rode around on some 20 year old Monroes for a couple of years until I had the cash (Going to college, having a girlfriend who was an expensive date, and working for slave wages sucked!)
Same here in Indiana... did all my research, got all the parts for lowering, had the car out for spring break finally and was JUST about to put all the new stuff on at my buddy's place and then it snowed and they put down salt everywhere and back under the cover it went.
Old Mar 27, 2013 | 04:43 PM
  #67
TKR 88 GTA's Avatar
Engine: HSR 350
Re: Lowering 101
They have magchloride crap up here that builds corrosion here on everything rims hubs anything aluminum lol my cars my daily too lol I have to research from the struts and shocks available someone told me kyb is a good bang for your buck lol do you already have the koni's lol and midnightfire I feel ya on that last part. I gotta a girlfriend that has no job and a one year old, on top of paying back my college loans on a 13.50/hour job that only gives 30hrs a week lol plus side babies give you a ton on tax returns lmao time to give the gta some much needed attention lol
Old May 30, 2013 | 11:01 AM
  #68
dgrejtest's Avatar
Re: Lowering 101
I'll report.
I've finally put new shocks and Vogtlands (for V8) on the car. They fit V6 perfectly and the stance is great.
Sorry for bad pic, but this is how it looks:
The car finally drives how it should.
Old May 30, 2013 | 12:22 PM
  #69
Firechicken355's Avatar
Car: 1989 Firebird
Engine: Slightly modified 355
Transmission: 5-speed
Re: Lowering 101
Just wanted to give you a heads up on lowereing. Even an inch drop will change the geometry of your suspension and require re-alignment of the front and one that isn't mentioned often is the rear lower control arm angle.
You may not notice much of a difference on a "normally" driven car, but if you do burn outs or race it you will find that after lowering you can develop a nasty wheel hop issue. This is bad because it can break parts, like the tailshaft housing of the transmission. I personally beat the snot out of mine and never had a problem until I put another person in the car with me. I just wanted his opinion on how the car ran (never had it on the track) The person with me was my Ford Fan uncle. To make it short, I tached it up and poped the clutch and out of nowhere my car started a violent wheelhop off the line. Thanks to others post, I identified the issue and determined that the 1" lowering springs combined with more angle from the additional 200 lbs of passenger changed the lower control arm angle enough to induce the wheelhop. Apparently these cars are known for this and just to be sure its gets fixed I ordered a heavy duty track arm and transmission crossmember.
Old May 30, 2013 | 09:32 PM
  #70
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Lowering 101
What you need are LCARBs, not a heavy duty track arm and tranny crossmember.
Old May 31, 2013 | 05:55 AM
  #71
Car: 1989 Firebird
Re: Lowering 101
blacksunshine'91
I neglected to mention the relocation brackets. I have those also, but not installed yet. Others have stated the correct lca angle is 3/4" to 1" drop in angle front to rear? But lets face it, the stock LCA's are flimsy stamped sheet metal stampings and so is the torque arm. Ok for a daily driver, but way too much flex for some serious performance. I beat mine like a redheaded stepchild.
Old Nov 21, 2013 | 05:09 PM
  #72
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: Lowering 101
Old Dec 26, 2013 | 12:17 PM
  #73
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Re: Lowering 101
FYI, the link in the first post for the Racecraft drop spindles is not working anymore. The correct link:
http://www.racecraft.com/index.php?m...dex&cPath=7_13
Old Jun 22, 2014 | 04:20 PM
  #74
94ElBanditoDeCa's Avatar
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
Re: Lowering 101
Originally Posted by //<86TA>\\
the rear control arm is supposed to be about level at ride height> the LCARB's help correct this after the car is lowered, since after lowering, the front of the lca is too low compaired to the rear, so you lower the rear mount to compensate.
this is not considered "camber" or "caster", those are only adjustable in the front.
So in other words I wouldn't have the LCA problem if I lower the ride height evenly front and back, compared to having the front slightly lower than the rear.
Old Jul 2, 2014 | 02:35 AM
  #75
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Re: Lowering 101
great info in here
Old Oct 2, 2014 | 04:33 AM
  #76
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Lowering 101
The New link to racecraft
http://www.racecraft.com/index.php?m...4ba4bc9ed2c331
Old Jan 11, 2015 | 06:21 AM
  #77
wheels777's Avatar
Re: Lowering 101
Is there a 2" drop spindle that uses the OEM brakes available? The Racecraft spindle require adaptor and different discs.
Old May 25, 2015 | 02:16 PM
  #78
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
Re: Lowering 101
So, ive had some belltech drop spindles sitting around for about 5 years now. Since i just bought a house ill have space to actually start working on my car again and had a few questions. Is there anythign in particular i should look out for when installing these? Based on the research i had done in the past and recent searches, everything should be pretty straight forward and drop in. They also work with the stock brakes as long as i didnt miss anything.
Old Jan 12, 2016 | 09:41 PM
  #79
nicksavio707's Avatar
Car: 1985 IROC
Engine: 350 5.7L tpi
Transmission: 700 r4
Re: Lowering 101
My silver 1985 Camaro IROC-Z with Eibach Sportlines lowering springs. 16" original wheels. Equipped with KYB shocks and a QA1 adjustable panhard bar. The perfect drop, not too much but not too little. Love how it looks and rides.
Old Jan 15, 2016 | 02:19 PM
  #80
roper88cars's Avatar
Re: Lowering 101
My Fire mist Red 1987 Trans Am with Eibach Sportlines lowering springs. 16" original wheels. Equipped with stock shocks and a UMI adjustable panhard bar, Subframe connectors, and 383 Stroker. The perfect drop, not too much but not too little. I to love the way it sits and rides.
Old Jan 15, 2016 | 02:22 PM
  #81
Re: Lowering 101
Forgot the Pictures.
Attached Thumbnails Lowering 101-img_7489.jpg   Lowering 101-img_7490.jpg   Lowering 101-img_7491.jpg   Lowering 101-img_7492.jpg   Lowering 101-img_7493.jpg
Old Feb 12, 2016 | 09:34 AM
  #82
5 speed's Avatar
Car: 1986 IROC
Engine: 60 over 350
Axle/Gears: stock..2:73
Re: Lowering 101
That is the stance I'm going for with my 86 IROC.
Did you go with the relocation brackets for the lower control arms? Are you running the stock lower control arms too?
Love your hard top..
Old Mar 11, 2016 | 08:44 PM
  #83
SpectroRacing's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Transmission: T5 5-Speed
Re: Lowering 101
I'm working with BMR to perfect some new Lowering Springs:
Old Mar 12, 2016 | 05:13 AM
  #84
Engine: L03 305 TBI
Re: Lowering 101
Dude, how tall are you?
Old Mar 12, 2016 | 09:49 AM
  #85
Car: 1992 Camaro RS
Engine: 305 5.0L
Re: Lowering 101
Lol 6'1" usually T-TOPs help, actually going to a racing event tomorrow and upset to hear it might rain, I will have to lay back to fit lol but playing slip and slide will be fun
Old Mar 12, 2016 | 03:13 PM
  #86
Engine: L03 305 TBI
Re: Lowering 101
Wow, I was thinking like 6'7", or something.
Get some Fiero seat brackets.
You'll be amazed at how much lower you'll sit
Old May 27, 2016 | 01:50 PM
  #87
RDPrime's Avatar
Car: 1992 Z28, 2000 WS6 TA, 2002 CETA
Re: Lowering 101
Will Eibach Sportlines be to low for a 92 Z28 with 20" wheels?
Old Sep 21, 2016 | 10:23 PM
  #88
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Re: Lowering 101
Ok so, two things I am trying to find out that I didn't see.
1. When lowering, are shaved or smaller bump stops required?
2. If adjustable lower control arms are going to be used, are the relocation brackets still required?
Old Sep 21, 2016 | 10:36 PM
  #89
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Re: Lowering 101
No to both. The lowering springs are usually stiffer, and don't allow that v much suspension travel. I have yet to hit the bump stops, I'm lowered about 1.7 inches in front and 1.5 in back.
The relocation brackets are meant to solve issues with hop. Not necessary, but if you lower it and start to experience a lot of wheel spin, the brackets could help.
Old Jan 26, 2017 | 05:50 PM
  #90
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Lowering 101
Any updates on drop spindles? $800 a pair from raceline seems a bit over kill. My 1 ton dually drop spindles are nearly half that price
Old Nov 21, 2017 | 11:17 PM
  #91
lpfeifer1980's Avatar
Re: Lowering 101
One good thing to add is that you may need a bump steer kit when lowering them. Seems like once you lower it more than an inch the car likes to be tossed around the highway if there are any ruts or uneven spots in the road. A little scary the first few times it happens.
Old Mar 26, 2018 | 02:38 PM
  #92
Jeff TX's Avatar
Car: 1988 Camaro IROC-Z
Engine: Dart 427 w Miniram and AFR 225
Transmission: Stg 2 LT1 T56 w/ Spec Stg 3P Clutch
Axle/Gears: QP 9" (3.89) w/ TruTrac
Re: Lowering 101
I am the second owner on my car and the original owner put lowering springs on it. I had it in the air the other day and the springs had a code 3801.301. Any idea what springs they are? I assume they are Eibach as they currently have a 3801-140 spring. Is the 3801.301 an out-of-production Eibach spring? Any info on this (e.g. spring rate, lowering height)? I couldn't find anything online and I'd be curious to know. Thanks
Old Dec 29, 2018 | 06:58 PM
  #93
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Re: Lowering 101
https://eibach.com/us/i-7388-pro-kit...4-springs.html
Old Aug 19, 2019 | 05:20 AM
  #94
firefox7518's Avatar
Car: 1989 TransAm GTA
Engine: 350ci
Transmission: TH700
Axle/Gears: Stock 9-bolt
Re: Lowering 101
I have the 2" drop springs from Detroit Speed Engineering installed in the rear and their weight jacks int eh front. The rear ones are working ok but are too low for me. The UMI torque arm is even hitting the tunnel now under load and the cat converter is constantly touching ground on bigger bumps or even if you want to drive off the street on a parking lot. Also the springs do not have any preload so they do not stay in place when you lift the car on a lift and not by the axle. I kinda don't like that the spring could jump out of the seat on a jump, and yes you can jump on certain streets here in Switzerland. It's a hilly country, haha. Our vehicle inspection will let me fail or actually even impound the car for being dangerous! Because of that and always scarping on the ground make me search for alternatives now.
I also have the Eibach Sportline springs. I first installed them but hey were simply to soft and you always had the feeling that something is bottoming out be it the shock of the bump stops. They were the reason to switch to the DSE ones. They sadly only have 2" drop springs and nothing else. Are the pro lines Eibachs stiffer?
Old Mar 8, 2020 | 08:40 AM
  #95
70's iron's Avatar
Car: 1983 Recaro Edition T/A
Engine: ex-CFI 305
Transmission: TH-700
Re: Lowering 101
Hi
Call me Stupid : I want better cornering springs with Stock height.
My car is a 1983 WS6 T/A, and I consider new UMI springs with 1.0/1.5 inch drop. But I also consider 1992 factory springs, will they mount on a 1983 ? Thx
Old Mar 8, 2020 | 03:16 PM
  #96
Engine: L03 305 TBI
Re: Lowering 101
I put Hotchkiss 1" drop springs on my car when I put 17" Hawks GTA wheels and new tires on it.
I'm pleased with the drop, was hoping the front might settle a bit.
BOY it rides rough though!
Old May 15, 2020 | 03:29 PM
  #97
Dragster Racer's Avatar
Re: Lowering 101
I wouldnt mind lowering my stock Iroc but dont want to do a ton of mods in case I want to sell it. Everything is original low miles so I would want to be able to convert it back easy.The drop spindles sounds like the best option but I dont see anyone talking about doing it? What are the pros and cons of drop spindles? Original post says using drop spindles allows for no changes to suspension up front.
Old May 15, 2020 | 04:13 PM
  #98
Jeff TX's Avatar
Re: Lowering 101
Pros - keeps originally designed suspension geometry.
Cons - they’re nearly impossible to find.
that said, you can change your entire suspension out in a day. Keep all the OEM parts. And if you want to sell as an original car, just takes another day to get it back to original.
Old Nov 29, 2021 | 11:53 PM
  #99
ahinojos943's Avatar
Re: Lowering 101
If anyone could help me I’d appreciate it so I bought a 90 iroc that came with a 4th gen rear end and am hoping to lower it a little bit, could I just by coil overs for a 3rd gen all around also is there anyone who recommends a certain brand of coil overs something in the median price range ?? Thanks
Old Nov 30, 2021 | 06:06 AM
  #100
Car: 92 Camaro RS
Re: Lowering 101
Rear suspension parts are all interchangeable from 82-02. Is there a reason for coil overs? Weight Jacks are ideal for most thirdgens in my opinion. Look to UMI either way.
Steven6282
Mar 23, 2012 10:38 AM
BonesNIS
Aug 27, 2011 07:45 AM
jja679
Feb 26, 2010 07:20 PM
bluegrass_boy62
Apr 22, 2008 05:01 PM
88Camaro350
Oct 24, 2003 05:44 AM
