any pics of largest wheels to fit stock?
Old Dec 23, 2008 | 09:21 AM
73duster's Avatar
I'd like to see pics and info on largest wheel combos on stock camaros.
Old Dec 23, 2008 | 09:53 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: any pics of largest wheels to fit stock?
go onto the wheels board and you will see hundreds of them.
and i saw a r&t pic of the 5th gen fbody and they are using 19 and 20 inch wheels on them. now i really dont like them, as if i did before.
Old Dec 23, 2008 | 10:40 AM
73duster's Avatar
i don't see a wheels board.
Old Dec 23, 2008 | 11:39 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have personally looked at a 91 camaro vert with 22's on it. WAY to big!!
And no, its not mine.
Old Dec 23, 2008 | 03:31 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I have a set, but they are not on the car yet. I think you will get the idea what they will look like.
Old Dec 23, 2008 | 03:52 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Just do a search, there are tons of threads. I personally think 17's look the best, maybe 18's but there are some people that pull off bigger wheels. I dont know his name but there is a black iroc with something like an 18 front 20 rear combo that looks pretty good.
Old Dec 23, 2008 | 04:50 PM
73duster's Avatar
i'm sorry, i should have been clearer. I want to know about 17" and how wide can you go without spacers. Any pics?
Old Jan 1, 2009 | 08:36 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
You'll have to have custom wheels made or do a lot of searching to find ones made to fit. Not many wheels offered in our offsets. Widest is probably x11 rear and x9.5 front.
Old Jan 1, 2009 | 08:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
17x11's will fit the rear with some minor hammering, but like said above, they are hard to find in our offset. you would need sometihng like 7" of back spacing.
Old Feb 5, 2009 | 01:54 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
I love my 18 by 8s
my 2 cents
Old Feb 7, 2009 | 11:37 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I have seen a car with 18x11s on all corners, but he had 2 or 2.25 inch spacers IIRC.
Old Feb 7, 2009 | 10:42 PM
shibbykins's Avatar
Car: 91 RS Vert.
Engine: 350 TBI cammd
ive got vette 18 x 9.5 rears and the fronts are 17 x 8.5 using 2'' spacers all around.
only isue that i ran into was the spacers werent propperly milled in the center hub things so i had to procure additional 1/4 inch slip on spacers in the rear. no rubbing at all
the fronts.... same issue and had to get another 1/4'' spacer. slight and i mean SLIGHT rubbing when turning.
front tires are 275/40/17 and rears are 275/40/18
Old Feb 7, 2009 | 11:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i'm running factory C6 vette 18/19 combo. Fronts fit great with 1.7-2" spacer. rear needs a big spacer for stock rear end, something like a 2.5" should do with some wheel well hammering which only takes a minute or two to do.
Jeremys87
Jul 14, 2022 09:08 PM
1984HO
Mar 19, 2021 11:59 AM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
mustangman65_79
Aug 9, 2015 03:00 AM
