manual rack? and accessory drive?
Old Dec 24, 2008 | 06:54 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Im looking to swap a manual rack into my 88 irocz. Anyone know what are all the cars that i can do a direct swap from?
What is all needed? Ive read just swap the gear box and supportig mods, but i have noone to trade so ima junkyard search.
Also could i just buy a steering box from say autozone?
Now to my accessory setup. i still have stock accessory setup. I want to run just the crank,alternator and waterpump and i need to know who does the cheapest setup.. I always thought march was fancy and expensive. Is there any setups i could junkyard off of?
Old Dec 29, 2008 | 09:02 AM
Shagwell's Avatar
Car: projects.......
Re: manual rack? and accessory drive?
For a manual rack there is no form of direct swap or any that are easy to install. Rack & pinion steering is tough to install on these cars w/o some fairly serious modification. - For manual steering you can just use an S10 manual steering box in place of the stock steering box.
All the info on either can be found easily with a search.
As for the brackets, there's tons of options. Do you want a "serpentine"(micro-v) type belt drive or just simple v-belt configuration? What do you have now? If serp, you can just buy the a/c delete pulley and run what you have. If v-belt, you simply drop the bracket(s) and belt(s) that you don't need.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
