UMI Subframe Connectors (Install Q's)
Old Dec 25, 2008 | 07:56 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Hey there folks,
Merry Christmas, hope everyone is doing good over the holiday season.
I finally got my UMI Subframe Connectors in a couple days ago and I had a question about installation.
What's the easiest way to install them? I know they have to be welded (duh), but how do you make sure they are held in the right spots to insure they are welded into place correctly and to make sure my LCA 's still bolt up like they should?
Can I just "bolt" them up at the lower control arm end (bolt my LCA's through them) and then swing them up against the car to be welded?
Would this work?
Any help would be greatly appreciated, im really excited about finally getting these and I wanna make sure they are put on right the first time.
Old Dec 25, 2008 | 09:24 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: UMI Subframe Connectors (Install Q's)
Bolt them to the lcas, swing them up, and make sure they're tight and weld them. (2 hours of prepwork atleast for welding). So ya pretty much exactly what you said and the instructions that come with them lol
Old Dec 26, 2008 | 07:48 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
I just did a set, pretty stright forward. A couple vise clamps held the front in place and pulled the gaps closer for welding to the front subframe. Nice pieces.
Old Dec 27, 2008 | 12:00 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I had the front of the car on ramps and the rear axle on jackstands to where the car sat level. Used the bolt for the lower control arms to temporarily mount the rear, used a couple of bottle jacks to snug them up on the front end. A couple of friends welded them in for me once everything was positioned. My exhaust had to be lowered to do the passenger side. Also, to make things a little more solid, they welded 1/4" and 1/2" round stock to fill the gaps between subframe connector and pinch weld and between subframe connector and floorboard. I have a few pictures I can post.
Old Dec 27, 2008 | 02:41 PM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Axle/Gears: 10 bolt 2:73 Posi
Please post the pics. I would like to see also, as I have these for my I-roc also.
Old Dec 27, 2008 | 05:23 PM
Al Hasse's Avatar
Only good pictures I can find are on the driver side.
Here, the lower control arm is undone, the bolt supplied with the subframe connectors was used to align the holes, then the connector was welded to the mount. You can also see some of the round stock used as filler to weld them to the body (though this isn't necessary).
This is the driver side (passenger side is similar except for the small extension which we assembled off the car, and the exhaust). A bottle jack was used only to snug the connector to the car. You can see also where we ground off the powder coating from the mounting pads and the places we wanted to connect them to the body, we also cleaned off the corresponding spots on the car.
Old Dec 27, 2008 | 06:22 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Al that is one clean car. from underneath. lol I see atleast 3 others around there also, Nice collection
Old Dec 28, 2008 | 01:37 AM
Al Hasse's Avatar
Thanks, but looks are deceiving. Friends did the hard part of welding, the only real part of that job I had was to lower the exhaust and replace it when finished. I was grease from head to toe, most of that I think came from the back of the motor, oil pan and trans pan.
Old Dec 28, 2008 | 01:46 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Awesome info and pics....
Thanks a lot guys, this is why I like TGO so much...
Hopefully i can get these installed within the next 2 weeks, kinda short on cash right now
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
