anybody running a S&W bolt in subframe connector??
Old Jan 4, 2009 | 07:39 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I picked up a S&W cage from a guy and while i was looking for the install diagrams I found this on their site http://www.swracecars.com/store/82-9...70=40-600.aspx. Looks like a nice piece and I'm thinking about it since I just picked up a 91 Z28 and want to put frame connectors in it. Anybody have any experience with them?
Old Jan 4, 2009 | 07:52 PM
Stephen's Avatar
Car: 87 GTA
Re: anybody running a S&W bolt in subframe connector??
Pretty nice design, but most people only use bolts on to get to their car to a welding shop, when they can't can't themselves.
Bolts might be strong INITIALLY, but they'll usually just wallow out the mounting holes & loosen up.
Old Jan 4, 2009 | 09:53 PM
WIll36's Avatar
Engine: 355, 408
Ya I wouldn't plan on just bolting them in I work at a shop so putting the car on a drive on lift to weld them up would be no problem. I'm just curious if anybody has run this piece before. The car came with a spohn torque arm and it doesn't look to me like the two would be compadable.
Old Jan 5, 2009 | 02:43 PM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
good luck spohn's stuff hardly works with its own products much less anyone else's
Old Jan 12, 2009 | 11:04 AM
poncho406's Avatar
Car: 84 pontiac firebird
Engine: 406 sbc
Transmission: powerglide
Axle/Gears: ford 9 4:33 gear
Hi, i've got that set up on mine ,works great but the only problems I had during the install when I discovered my body was twisted slightly ,had to chain the car down and and use a floor jack to straighten the car out and get everything to line up ,after the install doors shut better no rattles well worth the money
Old Feb 4, 2009 | 10:34 AM
WIll36's Avatar
Engine: 355, 408
Are you using their torque arm as well I'm almost ready to order the frame connector and thinking about selling my spohn T5 torque arm and using theirs and making my own T56 crossmember
Old Feb 6, 2009 | 12:40 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
that looks like a pretty sturdy piece.
its about twice the cost of most sfc's but i guess its worth it.
my camaro creaks and moans all the time. rattles are incessant.
i probably should go ahead and get some sfc's.
i might try this one out.
where do you weld everything if you get a bolt in one welded in?
just weld the heck out of everything where it touches metal or do you have to be more careful than this
Old Feb 6, 2009 | 06:31 PM
WIll36's Avatar
Engine: 355, 408
Well I'm leaning towards this, because it does seem to be the strongest SFC setup out there. Also if you use their torque arm too it's actually a pretty good deal for the two components together. If I install this I would weld the mounts that go around the LCA mount, where it hits the front subframe at the trans cross member and in the front where it meets the pinch weld. It would also probably be a good idea to do some stitch welds along the entire length of the piece as well.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mizz0313
Aug 12, 2015 06:45 AM
