Alignment Specs...
Old Jan 5, 2009 | 07:39 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Alignment Specs...
I recently rebuilt my steering, including ball joints. I also replaced the struts with KYB AGX units. I replaced the steering parts with Moog except the steering box itself which I adjusted according to an article I found on here.
The specs I used were:
+4.5* Caster
-.7* Camber
1/16'' total toe in
According to the shop where I took it, I couldent quite get all my caster and camber due to my factory mounts not having enough adjustment; but they are very close. I have a full print out if anyone is interested.
The car is quite amazing now in comparison to its previous state. Turn in is as crisp as I could want from my street car. What is most pleasing is that the shifty, darty, road steering car that I had before is completely gone. This thing is a pussycat even on the grooved out roads in my area. I cannot vouch for long term tire life at this point, but we will see.
Thanks,
Max
Old Jan 6, 2009 | 07:23 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Alignment Specs...
I've had similar settings with my allignment. But, mine's closer to 5-5.5 caster, -1.0 camber, and 3/32 (I think) toe out. Much nicer than stock settings. Now it's set at same caster, about -.5 camber, and no toe. Tie wear wasn't that much worse with the more aggresive allignment, but I was putting on my winter wheels/tires and needed an allignment after the LS1 brake conversion so I went with less.
Old Jan 7, 2009 | 09:30 PM
myvmax1's Avatar
Car: 91RS, 91RS
Yeah I knew there were more aggressive specs out there. I had done some reading prior to having the alignment done and it seemed as though a little toe-out was better for immediate turn in, but likely to cause scrub in long sweepers. Applying this to the street would tell me that scrub is unacceptable.
I want the maximum from my car (tire,susp.,chasis) but I am also looking to give my expensive Run-Flat tires more life than a typical auto-x low(Neg.) camber, toe-out alignment will provide. So after some research and some help from the good ol' TGO this is what I came up with.
More info if anyone needs....
Thanks,
Max
Old Jan 8, 2009 | 09:13 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I got the extra caster from my J&M mounts. Really nice pieces. I alligned it for auto-x (no sweepers, just alot of turns). Just never made it to auto-x lol. For that matter, most of the roads I drive around here have anything I'd consider sweepers. Pretty tight switch-backs for the most part.
Old Jan 8, 2009 | 10:49 PM
myvmax1's Avatar
Car: 91RS, 91RS
I've done some looking into upper mounts and have seen a lot of names thrown around. Hotpart, Sphon, Hotchkiss, ect..... Seems like the the steel ones with the extra strut height are the best choice.
Yours are J&M? You say nice pieces so I assume you are happy with the quality?
Thanks,
Max
Old Jan 9, 2009 | 10:01 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
The J&M have extra height built into them as well, just in a different design from Spohn's. I have the orginal design J&M's and am going to go to their new design when money permits. The only complain I have with them is the hood clearance. That's why I'm going to the new design that has no such issues. I really reccomend their pieces.
Mine:
New design:
Old Jan 9, 2009 | 11:13 AM
myvmax1's Avatar
Car: 91RS, 91RS
Man, those look plenty beefy....
I'd say these are next on the list of the suspension budget. It was tubular LCA's, but since I tightend up the front end with all those new parts I can really feel those upper mounts 18 year old slop. These will still clear my Edlebrock Three point STB right?
Max,
Old Jan 9, 2009 | 11:32 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yeah, once you get some new parts up front, the old ones really shine through lol.
I was worried about the same thing and started this thread. Check post #7. More good news about the Edlebrock piece is that it'll clear a LS1 swap as well as the stock TBI. lol, extra info.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
