BMR K-Member and Rack Qs
Old Jan 1, 2009 | 07:52 PM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Got my Chirstmas money and now its time to blow it on the car. Im going to get a BMR K-member and A-arms. This just came to me last night..what is Rack and Pinion Steering? How good is it and is it worth geting and what all do I need to go with? BMRs page has a Flaming River for $230. Is that all I really need? The car is going to be a street/strip/show car. One more thing while on the topic of BMR..Iv got the Sub Frame ties from them that are made for full lenght headers and exhaust. Can I use the "trak Pak" torque arm with them? Iv tryed to look and read but cant find what Im looking for..might ahve to call..
Thanks Guys
Old Jan 1, 2009 | 08:07 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Re: BMR K-Member and Rack Qs
Yes you can and it works really well i know because i have it on my trans am good luck with you choice i dont know which i would pick keep us informed
Daniel
Old Jan 1, 2009 | 08:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
keep in mind, the rack will reduce your turning radius, unless you can modify the spindles or use aftermarket ones made for rack and pinion applications. Racecraft makes them
Old Jan 1, 2009 | 11:15 PM
87_GTA_5.7's Avatar
I think Ill get the drop spindels made for them. Also the rack get rid the powersteering pump and steering box right? Im trying to save a little weight lol
Old Jan 2, 2009 | 07:49 AM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Youll still need the power steering pump if youre using a power rack.
Old Jan 2, 2009 | 09:30 AM
87_GTA_5.7's Avatar
I think im going with the manual rack to save pull on the motor..
Old Jan 2, 2009 | 11:56 PM
87_GTA_5.7's Avatar
Lookin on Hawks they show 2 manual rack and pinion sets. One is $600+ and the other is around $300. Whats the difference?
Old Jan 9, 2009 | 10:32 AM
BMR Tech's Avatar
Former Sponsor
If you plan on using the manual rack kit from us you need to have the K-member with the rack mounts on it. Did you purchase this correct one?
For the most part I do not recommend using the manual rack kit on a street car application for some of the same reasons you have been given. The installation of the rack kit is also not for the average car enthusiast and will require some fab skills.
Old Jan 9, 2009 | 12:25 PM
87_GTA_5.7's Avatar
I havent ordred any thing yet. I was going to and Im waiting to order a bunch of stuff at once..pay shipping once... The car will see some street use but most shows and strip use. If I get the spindesl from RaceCraft..what other problems could I run into? My goal is be deep 10s on a "stock size" drag radial. I want the car to look mostly factory..
Old Jan 9, 2009 | 07:19 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I used and installed the racecraft dropped spindles for R and P, racecraft k-member with pinto mounts, unisteer pinto rack, narrowed for 3rd gen camaro, PA racing pinto rack conversion steering shaft. Other than the problems with Racecraft K-Member it probably would only take a day or 2 to install.
My car is for street use, other than the steering is now arm strong instead of power, all of my muscle car were manual steering anyway, so no problem, and I have no change in steering radius with new spindles and rack
Hope that helps
Old Jan 10, 2009 | 07:40 AM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Thats good info there Rat. Its good to know that those spindles are really keeping the oem turning radius when switching to a rack.
Ed1LE
Sep 30, 2018 09:14 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
meeklay812
Oct 1, 2015 03:46 PM
Mdenz3
Sep 17, 2015 08:36 AM
luvofjah
Sep 10, 2015 10:41 AM
