car wobble
Old Jan 6, 2009 | 03:37 PM
venom204's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
car wobble
Ive got a question i just bought a 91 camaro and when on the freeway the car starts to wobble really bad and then goes away. The tires are in rough shape im getting those replaced today and aligned. What else would be causing it?
Old Jan 6, 2009 | 03:58 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: car wobble
Not trying to be smart. But, why not wait and see if the new tires/balance/alignment fix the problem?
Old Jan 6, 2009 | 04:01 PM
venom204's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: car wobble
nah i understand wasnt sure if someone might of had the same problem its just weird it doesn't do it all the time is all
Old Jan 6, 2009 | 05:13 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: car wobble
My wheel's have been balanced recently, but the rears still shake the car. It starts at ~65- sometimes it's worse than it is at other times which is weird.
You probably just need to have them balanced
Old Jan 6, 2009 | 05:26 PM
jms's Avatar
jms
Re: car wobble
Check your idler arm. It connects the drag link (the steering bar that crosses under the oil pan) to the frame on your right front steering. Push up and down on the drag link where it connects to the idler arm. If it moves up and down it is worn out.
jms
Old Jan 6, 2009 | 06:49 PM
venom204's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: car wobble
ok i took it to les schwabs and the tie rods are bad along with the front struts. the right front tire is worn and the back 2 are widened wheels with tires that where made in 97
Old Jan 6, 2009 | 07:15 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: car wobble
What a combination of not so good things.
You replacing the struts and tie rods? If so, it'd be a good idea to replace the strut tower mounts at the same time as the other two. That way, you'll just need one allignment. The mounts are usually are usually worn out if the struts are. Get some good quality ones. I put the cheapos from Advance Auto, and they were shot within a year. Also, the rear shocks are probably shot if the fronts are.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
