new guy front end question
Old Jan 13, 2009 | 02:42 AM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
Hi everybody, first post and im hoping i can get started with a right foot. Ive done a bit of searching and i didn't know what to put this under either engine swap or here. but my question is that i have a 84 firebird that had a v6 (2.8L)in it and the guy that i bought the car from gave me a 305 which was fantastic for $350 for the whole thing car and engine. I know that the 305 wont be able to use the mounts that are on the stock K-member, so im pretty sure i would have to goto the wreaking yard and pull the one out of V8 model. or is there some adapter that would work? and if i have to pull a K-member from the yard how hard is it? 2 man job or can i do it myself? and if im pulling that what else should i pull like the springs or just get new ones? Money is an object but i would rather do this right the first time. I looked at the one Spohn had, but i don't think i can swing the $1000+(or as a matter of fact the 500) unless it worth it and i wont have to replace anytime in the near future(altho i would liek to get this thing running so i don't have to hear the "i told you that was a pile of junk" from my girlfirend). Thank you in advanced
Old Jan 13, 2009 | 03:17 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: new guy front end question
Hi and welcome, altho this should be moved to the engine swap, Ill do my best to help you with this. I know for a fact that the crossmember holding the engine is the same from 82-92 all engines included. What Im not so sure of is if the 2.8 and the V8s share the same engine mounts. I would guess so. My guess is its a direct swap... physically speaking.
Old Jan 13, 2009 | 05:22 PM
Car: 1986 Trans Am
Axle/Gears: IDK yet
thank you, i didnt know what one to put it in because if somebody was to say that yes the spohn would be the better way to go, or if i needed to pull out one out of a donor car.
Old Jan 13, 2009 | 08:04 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Since your on a budget, you dont need to invest in a 500+$ fancy piece. Just ask in the V6 forum if the 2.8 mounts are the same for the V8s. Like I said, Im pretty sure they are.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
