Brace on top of panhard bar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
What is the brace ontop of the panhard bar called? I am working on replacing the fuel pump. I removed this brace yesterday but I was fored the cut the head and tail of the bolt on the passenger side to remove it. I need to replace the bushing and all now bu have no idea what the thing is called to start my search.
Re: Brace on top of panhard bar
JamesC
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
there is no bushing in the upper panhard brace/bar. Its a solid mount, that piece does not move, it just strengthens the panhard mount on the passenger-side of the car.
Car: 87 GTA
If your talking about a bushing in the brace, I bet your talking about the panhard bar, not the brace of THAT.
Got a pic?
Missed the bushing business. As mentioned, none involved:
https://www.thirdgen.org/forums/atta...d-dsc00274.jpg
JamesC
JamesC
Car: 92' RS
Engine: LO3
Ah, well crap. Now how am I supposed to get the rest of that bolt out of the upper brace? I guess I can try and drill it out but this is not going to be fun.
I thought it was just a bushing that I could cut out and replace.
you cant beat it out with a pin or another bolt or something?
Any other ideas for removal. Along with plenty of PB Blaster, I've tried a four-pound sledge on the thread side, an air gun on the head side as well as a huge breaker bar--and cold chisel/four-pound slege combo. I couldn't get my air hammer to work. At any rate, I've yet to make any impression on the bolt at all.
JamesC
JamesC
Car: 92' RS
Engine: LO3
Any other ideas for removal. Along with plenty of PB Blaster, I've tried a four-pound sledge on the thread side, an air gun on the head side as well as a huge breaker bar--and cold chisel/four-pound slege combo. I couldn't get my hammer hammer to work. At any rate, I've yet to make any impression on the bolt at all.
JamesC
JamesC
If you cut it out like I did make sure you push it out the head side since the bolt tapers and will not go out the other way!
Been considering drilling a hole in the center section, flooding the hole with PB Blaster, then using a punch to loosen the rust there before whacking the heck out of it again. Is the bolt the same size as the sleeve or a bit smaller (I ordered the bolt from GM, but it won't be in until tomorrow)?
JamesC
JamesC
Car: 92' RS
Engine: LO3
JamesC
JamesC
If you have a torch, use it on the sleeve without reserve and pound the crap out of it from the thread side. It was the only thing that allowed me to get the thing to budge.
The bolt is pretty snug and that sleeve tapers so you can't put it in the wrong way and the larger section of the bolt will not go through the slender section of the sleeve.
JamesC
Car: 87 GTA
You could do like I did on an intake manifold I did once, when the head snapped off.
I drilled the center of the bolt out, then stepped up in the drill bit sizes, until I was close the the close threads, but careful not to actually hit & damage then. Then I used a pick to clean out the bolt thread pieces.
Be careful not to drill fully through your bolt though & get metal bits in the cooling system.
I got the broken bolt out & just got a new intake bolt to use.
Not the easiest way, but it worked & damaged nothing (besides what was left of the broken bolt).
JamesC
Car: 92' RS
Engine: LO3
Why did you buy a new brace anyway? I cleaned mine up and painted it with por-15 since I had it out.
Hmm sounds like a mistake was made with the new brace. Now you are going to have to drill out the muffler side hole that is on the car and the spring side of the bolt will not have a very tight fit.
JamesC
1992 Trans Am
05-10-2023 07:19 PM
NBrehm
08-05-2015 07:57 PM
