Part list
Old Jan 24, 2009 | 06:15 PM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
Part list
Can anyone tell me a good parts list to start with as far as SFC go and torque arms. I tried looking through the search but I was just wandering what will be good start with. I didn't see a big kit of all so I want to come prepared when I go order these parts. Probably looking at bolt ons for now can weld them later.(just need some decent support with the new engine to last till i restore the body)
Thanks,
Jon
Old Jan 24, 2009 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Part list
check out UMI performance, Spohn performance and BMR. They all sell subframe connectors and torque arms, some people prefer certain companies over the others, i personally like UMI.
I do not believe any of these guys sell bolt in SFC. You will have to use Alstons SFC, Topdown solutions (TDS) sells them, or use the "jegster" bolt in ones that Jegs sells.
Old Jan 24, 2009 | 07:21 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Part list
pretty sure hotchkins sells a suspension hit, shocks/springs/SFC/LCA etc but not a tq arm.
its all about price and preference. UMI has nice stuff, BMR does too. but i also like jegs. i pic with whats gona fit my needs as far as performance and price.
i mix match. i have UMI adj panhard rod, and lower control arm relocation brackets. i have handmade LCAs and SFC and soon a strut tower brace, but i have a jegster tq arm and TDS wonderbar.
Old Jan 24, 2009 | 07:40 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: Part list
I personnally bought most all my components from Spohn. I have their panhard bar, lca`s and relocation brackets, torque arm, driveshaft, driveshaft loop, subframe connectors and wonderbar.
I have heard alot of good things about UMI, TDS, and BMR. As previously mentioned its a matter of personal preference and pricing.
Old Jan 24, 2009 | 07:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Part list
My method of thinking is go with manufacturers that work primarily with 3rd or 4th gens. J&M (Hotpart.com), Spohn, and UMI are good. I wish Hotpart was around when I did my rear suspension. I say go with weld in SFCs. Too much of a chance of play/movement with bolt ins IMO.
Old Jan 24, 2009 | 08:13 PM
Car: 87 TA clone
Re: Part list
weld in subframes are best but better ones are the bolt ins and then u get them welded in. same thing for the bolt in LCA relocation brackets. bolt in SFC and relocation LCA brackets are usually stronger and the regular weld ins physically since they have to spead the load over a wider area... but u just bolt them in and get them welded and theyre stronger... no play and no bolt elongation from twisting stress.
oh also forgot i have a jegster drive shaft saftey loop... add that too my list
jegster saftel loop is cleaner than the LAKEWOOD and is fully welded and designed for our cars. cheap too but it cant be taken apart to lower drivshaft like the lakewood since its all welded together... u would have to unbolt it from the floor pan. but i prob wont do that much so it doesnt bother me. buts its a very clean peice which is why i got it.
same goes for the TDS wonderbar. i dont have anyprobs with having to take it off to get my dual fans out. unlike sum other brands. they also look alil beefer the spohn or maybe he BMR piece IMO. also has 3 mounting holes compared to 2.
went with jegster tq arm bc i didnt want a tranny mounted arm. spohn/bmr have nice peices but are $$ i got mine used for cheap and its shorter than the BMR/spohn peices and gives me max clearance for my dual 3" exhaust.
weigh ur options and see wat fits best for u, price, preference, and what will work overall for ur goals/future mods etc
Old Jan 24, 2009 | 10:20 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Part list
I have all UMI stuff except I have the Alston (TDS) SFCs that are welded on. My UMI trq arm is a cross member mounted with a built in drive shaft loop.
Old Jan 25, 2009 | 12:36 PM
Car: 84 camaro z28
Engine: 5.7 carbed
Re: Part list
Okey can you give me a basic list of a good start to be safe. Like list them in improtance then i can buy like the top then work my way down the list.
Old Jan 25, 2009 | 01:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Part list
get subframe connectors first, and have them welded in.
then make sure you have good tires and shocks.
then you can start with he rest, i would get the LCA's and the pahard, then a torque arm.
Old Jan 25, 2009 | 01:11 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Part list
1 SFC's http://www.umiperformance.com/produc...ategory_id=113
2 Springs and shocks: I have no experience, mine are all stock.
3 Panhard since im sure you car is lower than stock and you'll center the rear. http://www.umiperformance.com/2021?category_id=107
4 LCA's http://www.hotpart.com/shop/index.ph...ct_detail&p=42
5 LCARBS http://www.umiperformance.com/2010?category_id=108
6 Strut mounts: Go with j&m or spohn
Edit: My opinion about a torque arm is this, if your making less than 350 horse, the stocker is fine, unless you want to change your pinion angle.
7 STB http://www.umiperformance.com/produc...ategory_id=167
8 Wonder bar: A stock one will be good.
Old Jan 25, 2009 | 01:19 PM
Car: 84 camaro z28
Engine: 5.7 carbed
Re: Part list
ok i have shocks and struts theyre stock but i just want a strong street car/ weekend warrior no plans on track runs. and I'll order sub frame connectors first but my car is still stock at least i havnt touched the height.
Old Jan 25, 2009 | 06:48 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Re: Part list
A 25 year old car will have "settled". Trust me, your car is not at stock ride height anymore, mine is down atleast .75-1.0 inch.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
