Bad Pitman Arm! Bad!
Old Feb 4, 2009 | 05:59 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, When I got my exhaust done a few weeks back the exhaust guy told me he couldn't give me a safety because..
1. The pitman arm universal was worn out
2. Brights didn't work
3. Hatch brake light didn't work
Now.. I have searched high and low in my town, the pitman arm is discontinued from the local dealership, GM Pontiac Buick.. Part Source doesn't have it, and 4 other shops are telling me all I can get is the Idler arm..
So what are the chances of the pitman arm actually going bad? The car has 164,000 KM on it.. (101,000 Miles) I was going to change the Idler and center link to see where I'm at.. But as far as I can tell I'm SOL as far as local.. Will I have to get it from Summit and load my credit card even more, or is there a Multi-fit part for other GM cars?
Old Feb 4, 2009 | 08:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Bad Pitman Arm! Bad!
The pitman arm is a non wearing item on a third gen. It's just a chunk of steel. You might have some other steering component worn out but not the pitman arm.
Old Feb 4, 2009 | 09:28 AM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
agreed pitman arm cant wear out... centerlink has the joint in it
Old Feb 4, 2009 | 09:48 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
“Non wear” but it can get worn RIGHT NOW in an crash, etc.
Therefore after you get a second opinion and verify you need one let us know.
We know plenty of places where you can get these so let us know if you can’t get one.
We hate to see a Camaro parked.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the day time!
Old Feb 4, 2009 | 02:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Damn colors!
Non wearable as in it will never wear out under normal driving conditions or the life of the vehicle. It can be damaged but only in an extreme situation such as an accident. It's not like tie rod and ball joint items which have movable parts that will eventually wear out.
It's a solid chunk of steel. It has holes at both ends. One end slides over the output shaft of the steering box and is tightened down with a nut. A puller is required to remove it. The other end has a hole for the center link ball socket to attach to.
The pitman arm never needs to be replaced unless it's been damaged or someone never attached the center link properly and the hole became worn out.
Old Feb 5, 2009 | 06:02 AM
Kevman's Avatar
Engine: 2004 LQ4
Changed the center link and idler, the steering is now tighter than I was hoping.. The way it looked underthere is like the Pitman arm had a tierod end looking thing...
PS.. I'm not a front end, brake line, or exhaust guy.. I have no clue when it comes to that stuff.. Thanks guys!
Old Jul 16, 2009 | 08:18 AM
outcast45's Avatar
Car: 91 Camaro
Engine: 305 TBI V8
Transmission: 5 speed
This posting helped out alot, I jacked up the camaro last night to see why the steering is sh** and thought it was the pittman arm, called around and cant get pittman arm, so was wondering if i was doing something wrong, guess its the centerlink. So gonna change that this weekend
Old Jul 16, 2009 | 09:29 AM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Could it be some slop in the steering box? I had a mech tell me my pitman arm is worn out, well I didn't just fall off the turnip truck yesterday. I could see a steering box getting worn but not a chunk of steel with two holes in it wearing out. Duh!
Old Jul 16, 2009 | 10:57 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
My guess would be the idler arm( the other yo yo didn't even know the correct name & just called it the pitmman arm). Before you do anything take a look at the posts before form about steering parts.
Old Aug 20, 2015 | 01:21 AM
Burkey's Avatar
my pitman arm has slop where the steering box meets the pitman arm do the splines on the arm or the splines on the gear box wàre out?. Where can I find a pitman arm?
Old Aug 20, 2015 | 01:31 AM
Burkey's Avatar
Mine has slop in the splines did you ever find one? What was the problem the gear box or the pitman arm?
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
