Front End Rebuild Checklist
Old Feb 16, 2009 | 06:03 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
After much reading in this forum but finding everything scattered around pretty confusingly (even in the stickied thread up top) I'd love it if you guys could take a quick look at the parts list I've compiled and tell me if this should cover me for a front end overhaul.
Centerlink
Idler Arm
2 Inner Rod Ends
2 Outer Rod Ends
2 Adjuster Sleeves
2 Lower Ball Joints
4 Control Arm Bushings (2 front and 2 rear of arm)
2 Sway Bar Endlinks
2 Sway Bar Bushings
2 Control Arm Bumpers
I'm looking at about 400 bucks by putting it all together piece by piece. Mostly Spicer stuff that is sold as AC Delco replacements and some MOOG components.
Old Feb 16, 2009 | 11:29 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Front End Rebuild Checklist
Seems like everything is in order. What do you mean by control arm bumpers?
Old Feb 16, 2009 | 12:31 PM
Car: 92 RS
Engine: a slow one
"Control Arm Bumpers" are what they're calling 'bump stops' on the site I'm ordering from.
Mine are FUBAR'ed.
Thanks for the input 91... Very nice car btw.
Old Feb 16, 2009 | 12:43 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Are you using the stock bushings that come with all those parts ? or upgrading to energys'?
Remember you have to press the bail joints out/in and same with the LCA bushings
Your list
Old Feb 16, 2009 | 01:02 PM
Car: 92 RS
Engine: a slow one
I already have poly sways and nylon endlinks. I'm going poly on the A-arms this time too.
I know about the press issue. I'm changing my front springs (some MOOGS) out at the same time. So I also got isolators and I'll rent a spring compressor.While it's all out I'm just taking the A-arms into a local shop and asking them to press it all in for a few bucks.
I am PRAYING that I have enough to get it all aligned when I'm said and done. The only alternative is to not drive it for 2 weeks until I can get it aligned if I run out of money
Old Feb 16, 2009 | 01:16 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Oh, I'd never heard them called that before. Mine are shot too. I'm waiting til I have the extra money and go with KONI progressives
You don't have to press the ball joints in and out. I've always used a 2x4, a BFH, and alot of finesse on mine with no ill effects lol.
If you drive it for two weeks with no allignment and all those new parts, you'll need tires too. Just wait til you can afford an allignment. Trust me on this one. I've done it before and so has my friend with his 95 Integra rebuild.
And thanks.
Old Feb 16, 2009 | 01:19 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Alignment really wont be a big issue, I had mine after my swap and it was barely any different.
Just make sure you measure the length of your tie rods, and if you can get them to the same size within a thread which is fairly simple if you measure, you should be able to drive and not be hanging on for life
Have you thought about some
Earls brake lines ? Did mine while i was up there, still gotta go back and replace the new rotors that are warped :/
Old Feb 16, 2009 | 01:31 PM
Car: 92 RS
Engine: a slow one
Good call!
I need brake lines too... I KNOW one of them are swelling.
I get a slight pull to the right under braking. Gets harder the harder I brake, and seems to change with weather and the stars alignment.
I've looked through my brakes 3 times since it started, that's all it could be...
Old Feb 16, 2009 | 01:38 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I got rebuilt calipers from Advance auto along with new lines. The lovely calipers managed to both have the same problem- the piston came out unevenly and destroyed the inboard pad (Hawk's HPS). I know it wasn't my installion as I'd installed the pads new and never had problems (on mine and several other cars). So, I did this...
Used the spindles from my parts car (91 Formy). Somehow, just changing that and not touching anything else, my toe was out 7/8 of an inch...
Old Feb 16, 2009 | 02:18 PM
Car: 92 RS
Engine: a slow one
That is a very nice swap
I'm embarrassed to say I haven't done much improvement to my car since moving out of a house and into an apartment
And 7/8's of an inch is alot to come out of nowhere... Bent spindle???
Old Feb 16, 2009 | 02:49 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yeah, it's alot better looking behind the wheels. I have abou $325 in all of it.
Don't feel bad, I've not done anything but that in the last 6-8 months. I've had my car for 5 years, so I've done a little at a time.
I don't know why it was so out. They didn't seem to be bent any. They looked and operate fine. I guess it's just crappy build tolerances.
Old Feb 16, 2009 | 02:57 PM
Car: 92 RS
Engine: a slow one
Yeah, I really need to get a nice brake setup.
But first I need a front end rebuild + panhard bar (bent mine a long time ago, been slacking on that since I don't drive it much)
THEN it's paint... Clearcoat is going.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
