anyone ever?
Old Feb 26, 2009 | 11:04 PM
412smallblock's Avatar
anyone ever?
anyone ever do anything different with their rear suspension othe than backhalfing? i am about to put a 9" in my car and what i was thinking was using stock style lower control arm and shock location but instead of the torque arm welding two tabs off of center of rear (roughly inline with torque arm mount) then run a custom double adjustable single bar from those tabs to the trans crossmember. anyone ever seen this done or done it theirselves? thanks for any input.
Old Feb 27, 2009 | 06:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: anyone ever?
like this?
http://www.umiperformance.com/2216?category_id=114
Old Feb 27, 2009 | 07:09 PM
Re: anyone ever?
Originally Posted by //<86TA>\\
no what im talking about is using a rear that doesnt have provisions for the torque arm. like mounting a single adjustable tube mounted to the top of the rear end by two tabs
Old Feb 27, 2009 | 08:22 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: anyone ever?
I've seen a car that has upper linkage that replaces the torque arm. Mounts from the top of the differential to somewhere on the bottom of the car. Can't remember exactly- been a while since I've seen it.
Old Feb 28, 2009 | 12:54 PM
Re: anyone ever?
thats the way a mustang is set up. i have a friend that had one that someone had done that to and the car never made it down the track.
Old Feb 28, 2009 | 02:02 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Re: anyone ever?
I wish folks here were more content oriented. I'm not sure what the hell you are trying to say. My guess is if you dig around a bit, you'll find some information.
Some organizations such as SCCA AS are allowed certain suspension modifications, but others are restricted. Some of these racers swap to a three link setup, the design criteria is somewhat(very) restricted by the rules, but apparently a few of them have put together rather effective setups.
By what I could tell from your semi-literate post, searching for 3-link, three link, or similar terms may just help you down the path you are inquiring upon.
As far as staying true with a torque arm setup, Ive seen a few "fox body" mustangs running a torque mounted below the diff. I'm not too familiar with mustang parts vendors. Though it was likely one of the bigger suppliers such as Griggs or MM.
Also might be worth searching through the fabrication section.
Old Feb 28, 2009 | 03:24 PM
Re: anyone ever?
First off if i wanted to hear from an *** hole I would fart. And if the moderaters want to kick my *** off the site for that its fine cuz I really dont give a ****. Second I have searched and have not found anything as of yet. All I asked was a simple "has anyone ever seen this" aparently you have not so why exactly did you reply with a bunch of stupid *** comments?
Old Feb 28, 2009 | 04:57 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: anyone ever?
why not just stick with what works.
torque arm and a set of lca's can go a long way.
Old Feb 28, 2009 | 05:00 PM
Re: anyone ever?
i really just dont like it.
Old Feb 28, 2009 | 05:52 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: anyone ever?
if it works, whats not to like?
Old Feb 28, 2009 | 07:36 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: anyone ever?
Actually, I'd say he does know what you're talking about. He was the one who showed me the type of three link I mentioned in my first post. Here is what he sent me.
Re: anyone ever?
prolly a thing with the fear of the unknown. im used to full out 4link and ladder bar setups. also was kinda wanting to do something different.
Old Feb 28, 2009 | 07:38 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: anyone ever?
There's nothing wrong with these suspensions. There are cars in the 9s and I beleive 8s and some very fast auto-x and road-course cars out there still running the stock torque arm/ panhard bar system.
Old Feb 28, 2009 | 07:45 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: anyone ever?
thats what I and alot of people think about being different....
A well setup torque arm suspension will out perform what ever your dreaming up...You might not personally have experience with the torque arm setup but alot of people going VERY fast are using them, just look into them more before counting them out...
Old Feb 28, 2009 | 08:01 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: anyone ever?
tell me how effective that is over a torque arm setup.
Old Feb 28, 2009 | 08:22 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: anyone ever?
I don't know. I've not ran it or talked to anyone that has ran it. I was just trying to answer the question of the OP- yes, there are more options.
I'm sure there are some advantages or it wouldn't have been design/ built for track cars. I say advantages would be possibly less weight, more adjustability, etc. Blyth would likely know more than me as he's the one who found it.
Old Feb 28, 2009 | 08:28 PM
Re: anyone ever?
ok well im sorry then. see i like that setup in the pics
Old Feb 28, 2009 | 09:17 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Re: anyone ever?
My assumption was that he was trying to adapt a 9" housing that didn't already have provisions for a torque arm. If that was the case I could see where copying an existing 3-link setup would be easier than accommodating a full length torque arm.
With the little information he managed to provide, I was only making guessing. Seeing that he thinks I'm an *** for not spoon feeding him. I'm through here.
Old Mar 1, 2009 | 02:03 AM
Re: anyone ever?
Well I didnt mean to say you were an *** just the comments made. Also if you look I did appologize
