fyi - steering box quick ratio box vrs standard
Old Mar 18, 2009 | 10:26 PM
kymission's Avatar
Just wanted to share some information. I intended to place in a base firebird a quick ratio steering box (Gear) in a 92 vert firebird with a standard ratio box from the factory. I investigated and everything seamed the same. specs, etc.. everything I saw indicated that they were exactly the same except the ratio.
What I learned when I installed is that the quick ratio steering box has a larger connector that connects to the intermediate shaft (rag joint) than the standard box does. Therefore the quick ratio box is not a simple drop in upgrade. you would have to replace the rag joint and the connector also. Something I was unwilling to do; so I simply placed a new standard ratio in place of the old box.
Old Mar 19, 2009 | 08:37 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: fyi - steering box quick ratio box vrs standard
Hmm....I gotta say, Ive never seen a different input spline shaft between the boxes. Even the S10 boxes are all the same input shaft end. I had a quick ratio WS6 box in my 87, replaced it with a reman standard box, and then back to a new quick ratio.. All this with the stock intermediate shaft, and this was between two different year thirdgens. One was an 87 WS6 and the other an 86 TA (non WS6).
Unless Im misunderstanding what you are explaining.... Where'd the new box that you tried that didtn work come from? Reman? Donor car??
J.
Old Mar 19, 2009 | 08:44 AM
kymission's Avatar
It was an a1cardone from rockauto.com I went to autozone and purchased a standard one and it worked fine. The spline was about 10-15% larger on the quick ratio one and the intermediate shaft connector was nut adjustable in any way.
Old Mar 20, 2009 | 06:20 AM
Car: 86 Trans AM
Sounds like they sent you the wrong part. Or they got a core that was the wrong part and it somehow made it back out marked for f-bodies. Then again...I dont know everything. So there could be a different box out there. I just know that my stock quick ratio box was exactly the same as the standard boxes that I got...as well as the reman quick ratio I picked up from Autozone.
J.
Old Mar 20, 2009 | 03:28 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Old Mar 20, 2009 | 03:37 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i installed a manual steering box from a 1990 s-10 best upgrade i did for under 100$ . its not like a power steering box with the belt broke, its really easy to turn.
Old Mar 21, 2009 | 02:00 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i wish there was a way to have a quick ratio manual steering.
i love only having to turn the wheel once to do a u-turn.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
happyhapka
Aug 15, 2015 04:42 PM
