What size are the bolt's that.......
Old Mar 24, 2009 | 05:20 PM
Samdweezel05's Avatar
I am looking to find the size of the bolts that hold on the rear LCR's and the panhard bar. Are these cars metric or standard? I find most, if not all of the bolts fit metric sockets and wrenches better than standard. I am looking for the shank size of the bolts. If they are standard I will know what the shank size is if you only know the size of the socket it takes to remove them. Thank's
Phil
Old Mar 24, 2009 | 06:15 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: What size are the bolt's that.......
I'm not sure of the head size, but they're definitely metric, along with everything else on the car. I'd guess the head is around 15-17mm, but it's been a while since I've had one loose.
Old Mar 24, 2009 | 06:47 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Bolt head size is 18mm. As for the thread pitch i think it is 1.5, but i am not positive on it.
Old Mar 24, 2009 | 06:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
almost all hardware , except the eng. is metric . i know it's a pita . thats just the way it is . good luck .
Old Mar 24, 2009 | 07:13 PM
I am just looking for the shank size so I can order parts to make my own adjustale LCR's and panhard bars.
Old Mar 24, 2009 | 10:25 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
The Panhard requires 2 stepped bolts. IIRC the bolt is 21mm, and the nut is 18mm. Go to your local dealer, they got them.
Old Mar 25, 2009 | 12:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yes, it's a goofy stepped thing.
Personally? Grab your drill and drill it out to 1/2", grab gr8 bolts and use imperial. That way if you drop/lose/let-rust, the existing bolts, you don't have to rely on a dealer anymore.
Old Mar 25, 2009 | 05:40 PM
That's what I wanted to hear. Sounds like a plan. Is it steped so the nut tightens on the sholder (step) of the bolt before it actualt tightens anything together and causes something to bind? Thank's
Phil
Old Mar 25, 2009 | 06:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
No, you don't tighten onto the shoulder. The shoulder ends midway through the bushing. The stepped part only prevents you from putting the bolt in "backwards". It's difficult to put it in backwards anyway, because you can't fit it through with the disc brakes on (or whatever is in the way...)
tom1985
Apr 19, 2016 07:55 AM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
