Front right tire vibration
Old Apr 8, 2009 | 10:43 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
after doing my ls1 brake set up i have a pretty noticeable vibration coming from what i believe is my front right wheel. at 40mph + its even so bad my passenger seat shakes. i checked out my suspension today and i have no play, and everything looks tight. just about all parts are new, inlcuding (springs, sway bar end links, ball joints, idle arm, struts, sway bar bushings, bearings, brakes). i've noticed when i make a u turn to my left the wheel binds, wheel skips or skids, and this is not the same making a u turn to my right. im leaning towards a bad ball joint but am unsure how the vibration would occur and need some help, any input is apreciated thanks
1992rs/ss
Jan 31, 2025 05:10 PM
zayne0
Aug 24, 2015 07:22 PM
db057
Aug 22, 2015 08:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
