front wheel bearings leaking
Old Apr 13, 2009 | 09:25 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
i just bought this 89 and both the front wheel bearings are leaking out of the dust sheild. i have pulled the tires off the front to check the brakes and they are damn near brand new, but hadnt noticed the leak yet. what shoud i do?
Old Apr 13, 2009 | 09:49 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: front wheel bearings leaking
sounds like a no brainer to me . new seals , after clean and re-lube . good luck .
Old Apr 13, 2009 | 10:14 PM
sloick's Avatar
Car: Many
Engine: Several
sounds like a winner to me.
Old Apr 13, 2009 | 11:29 PM
basiccamaro's Avatar
There aren't any seals for the outer bearings under the spindle nut caps, only the inner bearings have seals.
You've probably have too much grease in the hub. Or maybe the old grease has thinned down under the heat of disc brake usage. Some of the newer small containers of axle grease now say "for non- disc brake applications". I guess the other type is for higher heat or something.
I'd pull it all apart, clean everything and repack the bearings with the proper extreme pressure axle grease.
Old Apr 14, 2009 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Dust shield or dust (grease) cap?
JamesC
Old Apr 14, 2009 | 06:49 AM
sloick's Avatar
Car: Many
Engine: Several
JamesC
the cap.
i figured it had something to do with the heat of the brakes. ill pull it apart today and re-pack them. for the $20 in parts im buying new bearings just to be sure. thanks guys.
anesthes
Mar 10, 2016 10:35 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
