alignment?
Old Apr 16, 2009 | 08:26 PM
superT's Avatar
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
alignment?
just wondered if you need to get an alignment if you only replace the struts and nothing else
any help would be great
Old Apr 16, 2009 | 08:32 PM
Stephen's Avatar
Car: 87 GTA
Re: alignment?
The struts control your camber.
If your smart, you'll mark the strut mount locations on the fender wells, before you unbolt them, then you can get it pretty darn close, without paying for an alignment.
If you have one of those lifetime alignments, just go tell them it doesn't seem right, but don't mention the new struts unless they ask.
Old Apr 16, 2009 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: alignment?
you dont have to remove, or move the strut mounts to change your struts. No alignment needed
Old Apr 16, 2009 | 10:58 PM
superT's Avatar
Re: alignment?
ok thats what i was thinking because the previous onwer had the mounts replaced and i have only put about 5- 7000 miles on the car sense i have owned it and wasn't planning to replace them unless they cause a problem with the steering or something later on after i put on the new struts
Old Apr 17, 2009 | 04:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: alignment?
provided the previous owner had the car aligned after he replaced the mounts, you are good. Does the car track straight? do the tires jump, or push, when you are turning at close to full lock?
Old Apr 19, 2009 | 10:46 PM
superT's Avatar
Re: alignment?
well i personally had the alignment checked and it was "perfect" says the shop that checked it. and as of the last time that i posted i have got the struts and shocks on the car and it drives perfectly fine and it feels way better.
fyi- i installed lakewood 90/10 on the front and i put summit three ways on the rear and they are set at 50/50. car feels way better when i bring it up on the converter and let her loose, weight transfer is way better and the ride didn't really suffer from the 90/10's like every place said it would.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
