Steering column installation **PLEASE HELP**
Old Apr 17, 2009 | 07:36 PM
IROC-J28's Avatar
ok so im doin the column in my 87 Iroc and it was all goin fine untill it came time to bolt the new one to the knuckle on the shaft. I tried to connect it with the column unbolted and it would not fit into the shaft, then tried to bolt up the column and slide the shaft into the knuckle that way and this time it seemed to short. Now im not just an idiot mechanic, ive been doin these for years but every time i do a thirdgen F-body it is the hardest thing to do. Please any help would be greatly appreciated
Old Apr 17, 2009 | 11:15 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Steering column installation **PLEASE HELP**
Are you talking about the intermediate shaft? The one with the rag joint that attaches between the steering box and the steering column?
Old Apr 18, 2009 | 09:41 AM
IROC-J28's Avatar
yep thats the one.
Old Apr 18, 2009 | 09:55 AM
IROC-J28's Avatar
wait its the joint that the base of the steering column slides connects with the shaft
Old Apr 18, 2009 | 01:24 PM
Kevin84Z28's Avatar
If it's this piece 'pictured' then that shaft has a slip joint. The intermediate shaft is actually two pieces. One slide into the other. You should be able to pull the shaft up towards the steering coloumn if it's just a little short. The piece pictured is telescopic in other words.
Attached Thumbnails Steering column installation **PLEASE HELP**-steering-shaft.jpg
Old Apr 18, 2009 | 01:31 PM
IROC-J28's Avatar
ok i got you, So its should lengthen enough to get it in. thats what i thought because they do that for crash safty but i couldnt get it to budge (rusty). im thinkin about jus takin the shaft out completely to work on it because i have no room around the brake lines and exhaust manifold
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
