new springs
Old Apr 18, 2009 | 01:40 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
new springs
i am getting new front springs.
will standard 5.5" OD springs work?
i think i remember hearing that they will fit just fine.
if so then what do you think about a 11" 900# spring.
it should give me 2.25 inches drop without any spacers if i did the math right.
i can run a spacer if i need to raise it up a bit
Old Apr 20, 2009 | 03:54 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: new springs
I think you'll need the springs with the flat end/ open end so they fit the k-member and a-arm. I'm not sure about the drop, though. Been a long time since I did my research in that department.
Old Apr 20, 2009 | 07:48 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: new springs
i was going to get closed and ground / closed.
thats how the stock ones are i believe
Old Apr 20, 2009 | 09:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: new springs
The top is 'flat', and the bottom is 'open'... at least that's how I'd describe it.
For what it's worth, I'm planning to get 9" 750# springs with weight jacks (my street set; my track set will probably be 850-900, same or a little less height). The jacks are about 1 7/8s thick when all the way down, with about 2.5" of adjustment. So figure a ~11" tall 750# spring. From what I'm told, I'd be able to sit the car on the bumpstops with the jacks all the way down and be about 2-2.5 down from stock all the way up. From the information I've found, I would think that you'd want a little taller than 11" tall with a 900# to be 2-2.5" lower than stock.
Old Apr 21, 2009 | 12:47 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: new springs
here is a chart i whipped up
remove the .doc from the end so it will be .xls]
feel free to change values around however you want.
the formulas for drop are dependant on force, free length, and rate
File Type: doc
Old Apr 21, 2009 | 02:18 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: new springs
That's some really nice work. That formula's (the one with the free coils, rates, etc) been on here for a while, but no one's thought to put it in a Excell or anything helpful/quick. Everyone would just have to weigh their nose (or so I would think) to determine the spring choice. You might want to add that option in the spread sheet. I'd imagine the weight of the car would play a major role in the choice of springs. I'd like to see how it plays out in the real world.
Seems like it'd give me a ~ 3 inch drop on the jacks with the jack 'closed'. I need to weigh my front and see how that changes it.
Old Apr 21, 2009 | 04:48 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: new springs
i got the weight and force from a buic GN forum. hopefully that was for our cars now that i think about it.
oops
ok, well now i need to take some measurements.
any of the aftermarket suppliers want to step up and give me an a-arm motion ratio?
that would be distance from bushings to ball joint divided by distance from spring mount (on center) to bushing
Old Apr 21, 2009 | 07:19 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: new springs
Give Sam Strano a call. He'll be able to help you a great deal, I would suspect.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
