lca's still not right
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
hey guys......I put about 1 inch of rubber under my rear springs at the top where they meet the body to see if it would make my lcas at least level but they are still to high in the back and the car is now sitting about right just slighty higher in the back than the front..It helped the ride and handling very much and took some of the wheel hop out (i boxed the lcas at same time not 100% if it was that or the springs or a combo of the 2)but i know i need to get them level or down a little in the rear but i wonder why there still up some in the back like something is off or is this common with all stock setup any help would be killer thanks guys(experts)...........
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: lca's still not right
Is your car lowered? If so, that would cause your LCA angle to be off.
You could install lower control arm relocation brackets.
Car: 87 GTA
Rubber on the springs won't do much for the LCA angle.
How are your LCAs sitting right now? Rear higher than the front?
Car: 87 iroc z
Engine: 358 tpi
yea the rear is just a little higher than the front just enought to see and its all stock not lowerd any
(yet) but im getting wheel hop after i put in the powertrax.The lifting helped some but im wondering why their not sitting right and if something might be wrong im going to install lcarb's and put in sfc but im wanting to make shure something isnt wrong causing the lca to be leaning the wrong way now with a stock setup
Car: 87 GTA
Or a previous owner put in lowering/cut the springs & you just don't know.
Below is a link to show you what we have to offer!
http://www.umiperformance.com/produc...ategory_id=108
Brad
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
LCA relocation brackets! Unless you just want the rear higher in the air jacking up the rear to get the lca's right isn't the way to go. I have LCARB's, boxed stock lca's with poly bushings and SFC's and have NEVER had any problem with wheel hop. I set my lca's so they're about 1" lower in the rear than the front.
Do you have sub frame connectors? If not I recommend them. Not only do they make the whole chassis firmer but they may solve you hop issue.
Car: 87 iroc z
Engine: 358 tpi
thanks alot guys from what everyone is saying im guessing my frame isnt tweaked just 20 years of old lol which is good news when i get done it will be a 2011 model only better.I had always planned on the lcarb since i read about them a couple years ago but was just wanting to make shur i didnt need to do something elts b4 i did that and sfc thanks agin everyone
(this is such a damn good sight)
Car: 87 GTA
I'd suggest getting new springs, before you add anything to "fix" the problem. Otherwise, your just putting a band aide on the car.
Car: 87 iroc z
Engine: 358 tpi
You know what that comment has made more sense than anything iv heard in a long time lol
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
listen to stephen...
he knows his stuff
(mostly)
just kidding stephen.
(mostly)
alright, enough of that
install new rear springs, if the rears are still higher up, put in LCARBS.
Subframe connectors wont help lower the rear of the LCA's, and if your frame is tweaked, get it straightened BEFORE you install the subframe connectors or it will be STUCK THAT WAY.
unless you have wrecked it though, i would venture to guess that the chassis is at least 90% ok.
if it tracks straight on a level road, then you are in the clear.
he knows his stuff
(mostly)
(mostly)
Car: 87 GTA
Car: 85 Camaro IROC
Engine: 5.7 TPI
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
