TQ Arm question, is it needed or not??
Old May 16, 2009 | 03:14 PM
BigZ388's Avatar
Car: 1984 Camaro Z/28
Engine: 425hp 388 Stroker
Transmission: TCI TH400
Axle/Gears: Ford 9" 4:10s
See my 1984 camaro orginally came with a 5spd, well now it has a built 700r4 auto, so the TQ Arm bolts up differently between the two, and i cant find a way to make the orginal one work on my 700r4. So can i just remove the TQ arm completely or do i need it, and if i remove it what kinda problems would i have? The car will be driven around locally when the weather is nice and at the strip every friday night!
Old May 16, 2009 | 03:17 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: TQ Arm question, is it needed or not??
yes, you need the torque arm, what's not bolting up? a torque arm is the same be it a t5 or 700 car
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
are you kidding me? of course you need it. If it wasnt needed why one earth would it be there?
It holds the rear from rotating. If you remove it, the rear will twist upwards and probably destroy the driveshaft and rear suspension.
You need the correct torque arm bracket for hte t5, or an aftermarket torque arm relocation kit or crossmember mount torque arm setup.
Check out UMI, Spohn, or bmr for torque arm kits.
Old May 16, 2009 | 03:31 PM
BigZ388's Avatar
LOL...Ok well i thought it was needed but wasnt sure, stupid question just was checking! Thanks
Old May 16, 2009 | 03:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
dont feel bad, your not the first person to ask this
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
