Control Arm didn't drop
Old May 28, 2009 | 12:48 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Hey all,
I just have a quick question. I see on a lot of posts that if you don't have a jack under the control arm when you disconnect your linkages and strut, then there is danger of the control arm dropping and spring popping out. This made me a little worried while working on my front end. I have a safety chain around the spring just in case, and put a jack under my control arm. I have EVERYTHING disconnected on the drivers side. I tried lowering my jack ever so slightly, and then a little more, until the jack was just below the arm... and the lower control arm hasn't moved at all. Does this mean my control arm is rusted in place? Or is it only a possibility that the control arm would drop?
-Andrew
Old May 28, 2009 | 01:15 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: Control Arm didn't drop
is it still attached to the ball joint or something? because something's gotta be keeping it in.
Old May 28, 2009 | 02:41 PM
50bmgshooter's Avatar
how tight is your safety chain ? ill bet the control arm moved and you didnt notice it, then the chain tightened and stopped the arm from moving
Old May 28, 2009 | 03:10 PM
wshbrn91's Avatar
The chain is pretty loose. No way the chain is holding it...
Old May 28, 2009 | 05:17 PM
ok in that case id say that
1 your springs are shot
2 your control arm bushings are shot and the metal sleeve in them are rusted to the control arm bolts
? how hard is the ride in your car and how low is the car?
Old May 28, 2009 | 05:23 PM
Stephen's Avatar
Car: 87 GTA
Any way you can take a pic of it, showing it?
My guess is, your missing something that needs disconnecting, or it is already at full droop.
What/Where do you have the chained wrapped to?
Old May 28, 2009 | 07:00 PM
wshbrn91's Avatar
Ill snap a picture tomorrow.
Old May 28, 2009 | 08:36 PM
SmokeShow's Avatar
Car: 1988 IROC Convertible
Do everything in this order to drop the lower control arm:
-take wheels off
-have steering unlocked
-remove sway bar clamps from frame (2 bolts,1 clamp, 1 rubber bushing per side)
-turn wheel full crank towards center of car (working on driver side turn wheel all the way to the right, reverse if working on passenger side)
-place a jack under the control arm to apply pressure on the suspension
-remove cotter pin from lower ball joint
-remove nut from lower ball joint
-lower jack down from control arm slowly
heres where it gets loud and scary if you havent ever done this before lol. If the control arm doesnt break loose from the spindle then put the ball joint nut back on a couple of turns and give it a couple of taps with a hammer until it breaks loose.
-Put the jack back under the control and apply pressure back to the suspension
-Take the nut off the lower ball joint
-lower jack again and you should be able to remove the springs and have the control arms free from the spindle
You should now be able to work on your struts without having to worry about the springs slamming off. Ive done this so many times now that I just hammer the ball joint once the nut is off and watch the control arm whip down lol
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
anesthes
42
Oct 24, 2015 07:30 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
