rattling from rear
Old Jun 4, 2009 | 11:07 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
rattling from rear
Im having some rattling sounds from the rear after changing axles, just want to check if the shock are loose from the top.
Its not exhaust and theres nothing loose under the car, been to an exhaust shop been on the hoist shook everything and found nothing wrong.
Just need a page to show how to remove the plastic covers in the back to check the top of the shocks.
Old Jun 5, 2009 | 01:44 AM
*18436572*'s Avatar
Car: 83 z28
Engine: vortec5.7/predator/msd/lunati/teamg
Transmission: th350/transbrk/rev-manual v body
Axle/Gears: Ford 9 inch 4:56
Re: rattling from rear
ratting ? it may not be related to the recent work you did, I would say safely run it on jack stands (having you a second pair of ears always helps) and see if you can hear it from the outside and double check all you fasteners
Old Jun 5, 2009 | 08:28 AM
transamice's Avatar
Car: 87 GTA t-top
Done that, had it on jacks and on hoists with numerous people.
Shaking everything on the bottom, sway bar, calipers anything removed or new.
Old Jun 5, 2009 | 08:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
It's been awhile, but you may be able to simply pull the carpet from under the plastic. The shock is covered with a white foam piece that lifts out.
JamesC
Old Jun 5, 2009 | 09:58 AM
transamice's Avatar
Car: 87 GTA t-top
Got it, easy enough but still have noise.
Thanks guys
hectre13
Dec 11, 2023 08:14 AM
xxx3man`
Sep 23, 2015 10:37 PM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
