Weird rattling noise in front
Whenever i go over small bumps.. It sounds like 2 sets of steel chains rattling.. Its going on in the front end.. Sounds like something is very loose. Any ideas?
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: Weird rattling noise in front
I got a 91' Bird >> Same thing...... New rims and tires balanced and inflated properly, replaced struts and end link bolts. While on jacks, pulled and yanked on everything >> Tie-rods, springs, breaks, framing, exhaust, drive shaft >> NOTHING BUDGED! Subscribed! I have heard this question asked many times. Same problem? Possible... Good question....
Ahaha.. I freak out everytime i go over bumps because i think the wheels are going to fall off. lol. Looked underneath and didnt see any loose bolts or anything so im stumped
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Easiest way to tell if it's sway bar related it to remove one of the links and take it for a drive. If the noise is still there, it's something else.
Sounds like a sway bar end link problem, as mentioned above. It should be pretty easy to spot if it is, just reach in there and play with em and see if they rattle.
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 11, 2015 10:11 PM
