anti-rattle spring
Old Aug 4, 2009 | 04:36 PM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
anti-rattle spring
Ok, my left rear brake pads have been rattling. I bought anti-rattle springs. how do i put them in? does anyone have a diagrams on how to do it?
these are the anti-rattle springs i got.
Old Aug 4, 2009 | 04:41 PM
Guest
Guest
Posts: n/a
Re: anti-rattle spring
Those are for the front. If you have the original disc brake rears used in 87, the clip is C shaped and is the size of the outer diameter of the brake piston.
Old Aug 4, 2009 | 04:49 PM
Axle/Gears: Idk
omg. so i just bought the wrong part? where can i get ones for the rear? and do you have to remove the caliper to do it.
Old Aug 4, 2009 | 05:28 PM
Guest
Guest
Posts: n/a
I dont know who would carry the rears, never looked. Anyone that carries a decent selection of brake parts should have them. I dont think there's any way you can get the ones onto the rear without taking off the caliper even with a lot of time and effort, there is just no space to work with. Only 2 bolts/pins hold it in place, just remove them.
Old Aug 4, 2009 | 05:49 PM
Axle/Gears: Idk
if i take off the two bolts, what do i have to do next. and will i have to bleed the brakes again?
Old Aug 4, 2009 | 05:56 PM
Guest
Guest
Posts: n/a
Take out the two bolts/pins holding the caliper on, slide it off the rotor (should be able to do both sides without messing with the brake line) take off the inside pad, put the clip around the piston with the two bent out pieces at the bottom of the pad, hook the pad to the clip, put it back together.
Old Aug 4, 2009 | 07:12 PM
Axle/Gears: Idk
thanks. im going to go shopping for the right part now.
Old Aug 13, 2009 | 04:21 PM
Axle/Gears: Idk
i have the part now, and how do i put the spring in.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
