inner tie rod fix
Old Aug 6, 2009 | 06:48 PM
Sully89Firebird's Avatar
Car: 1989 Firebird Formula
Engine: Stock 305 TPI
Transmission: 700R-4 w/ Shiftkit
Axle/Gears: Stock 2.73
inner tie rod fix
Hey guys, Today, I was coming out of the local gas station when I decided to give a kid, that i hate,with a little chevy caviler with a fart can a piece of third gen power. i took a sharp corner at like 55mph and it heard a loud bang and the front end never seamed the same since. The front end shakes very bad, especially at stops. it dosent like left turns so a guy told me to look on the right for a problem. I took a look under and found that what I think is the inner tie rod or stabilizer. i thought it was a torsion bar at first? But it has popped off on the right side. I took a couple pictures to show you guys so i can fix this problem. Thanks I want to fix it tomorrow before I go to work so I would like quick help on this one. thanks guys
-I provided a picture of the right side (the broken side) then a picture of the left (the good side) then i picture for fun.
Attached Thumbnails inner tie rod fix-picture-507.jpg   inner tie rod fix-picture-508.jpg   inner tie rod fix-picture-509.jpg
Old Aug 6, 2009 | 07:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: inner tie rod fix
That's not a tie rod end, it's a sway bar end link. Just get a new pair of endlinks. You can get polyurathane if you want - they usually have them on the shelf at Autozone for like $30 a pair. Should take 15 minutes to do, unless the bolt is rusted on the 'good' side, then you need a few minutes to cut it off with the hacksaw.
Old Aug 6, 2009 | 07:26 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You really showed that kid
But easy fix. You'll need two 9/16th wrench's (or maybe 14mm)
You can get replacement end links for like 6 bux.
Also, good idea to replace both sides at the same time.
Might wanna soak some PB Blaster on them to help loosen ththe old ones off.
Old Aug 6, 2009 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
or just cut them off, might be easier.
Old Aug 6, 2009 | 07:59 PM
Thanks guys. I looked through my Chilton repair manual and I couldn't find it, so I immediately remembered I was a member of the third gen board and you guys could help me out. So thanks I will pick up one at napa tomorrow and fix it. I will comment back if i got any problems with the fix.
Old Aug 6, 2009 | 08:55 PM
krisb410's Avatar
True, but by the sounds of it, I really didn't think he had a large collection of tools, and cutting it off was already mentioned, just giving him another option.
Old Aug 7, 2009 | 04:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you would be correct, i missed that.
Old Aug 13, 2009 | 04:18 PM
Car still shakes
Hey guys, I replaced the sway bar endlinks, it was pretty easy and cheap. I replaced both of them because 2 came in a kit for like 20 bucks or something. Then I took the car out for a drive and it still has that shake to it. I feel it the most when i am in idling at stop signs and red lights. Its kinda embarassing when I stop for a light and the car just shakes at like 700 rpm. It is definatly comming from the front end. I noticed that I dosent really happen when I am idling in park or when i first cold start the car. It just started this once i broke the first endlink. I thought if I replaced both endlinks, this problem would stop. Any suggestions?
Old Aug 13, 2009 | 05:28 PM
Car: 1992 RS
Engine: Carbed 350
Re: Car still shakes
So, it's the motor that's shaking then. First place I'd look is vacuum lines - a small vacuum leak can make an idling engine run like crap.
Old Aug 13, 2009 | 05:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the tierod ends are not going to precent the car from shaking at idle.
Do you have a broken motor mount or trans mount?
Aside from shaking, how does the car run? is it running smooth or is something wrong
Old Aug 13, 2009 | 06:14 PM
this is what i am going to do, i am going to start a new thread about the big problem that i think is all linked together. i should have started it a long time ago when i bought the car. i will reply with the link to the new thread in the general engine tech section of the board.
Old Aug 13, 2009 | 06:56 PM
here is the link to the big thread with the bigger picture on the issues with my formula
https://www.thirdgen.org/forums/tech...ml#post4251561
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Street Lethal
Sep 7, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
