8point cage install tips?
Old Aug 7, 2009 | 01:03 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Okay I got my comp eng. 8 point. I will be installing it this week hopefully.
Is there any tricks I should know? Should i just tack the back half to hoop in, then slide it out and weld it. Then slide it into place and weld all the plates down?
Is it normal for the main hoop to be a few inches too long? I placed it in the car and it is a bit long.
Also does anyone have pics of how the welded the main hoop to the floor?
Thanks Jay
Old Aug 7, 2009 | 05:36 AM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Re: 8point cage install tips?
determine where you want all of your floor plates to be and form / tack them in place. Then fit the main hoop (you may need to hook a ratchet strap to the legs and squeeze the legs in; it seems pretty common and i had to do it with mine). After you have the main hoop fitted, tack it to the floor plates. Then I would fit the cross bar to the main hoop (the one that your harnesses hook to) and tack that in place. You can then fit the two tubes that go down the back and tack them to the main hoop (place several tacks around it to try and keep it from moving when you weld around the top). With that being done, just cut the tacks where the tubes connect to the floor plates; you should be able to manipulate the assembly so you can weld around the tops of the rear support bars.
After you've done that, put the main hoop / down tube assembly back in place, check all your measurements, tack weld it in place and begin welding. Just take your time and skip around welding to try to prevent warping.
Yes, it is normal for the main hoop and all other tubes to be too long. I had to cut like 6 or 8 inches off of my main hoop.
Also, take it slow when doing your notches and try to not have a lot of gap in them. I'm sure some other people can chime in and add some info.
Old Aug 7, 2009 | 06:18 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
i wouldn't take it back out to weld it. welding it without it in the car is going to cause the bars to move around alot with the heat created be welding. jg is right though about the ratchet strap to close the main hoop in, it's not quite narrow enough to weld it to where the floor plates fall.
here's a thread i did a while ago:
https://www.thirdgen.org/forums/orga...keered-no.html
Old Aug 7, 2009 | 09:42 AM
Jay_rich's Avatar
Car: 1987 Z28
Thanks very much!....Matt your pics were exactly what I wanted to see!
Jay
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
