Stupid Suspension Problem... Help!!!
Old Aug 14, 2009 | 12:03 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
so i’m in the process of dropping in another set of tokicos... never had a problem with an install before, usually done in about 2-3 hours... well after getting the rear finished i started on the front passenger side and thats when the pits of hell opened... i’ll spare you the b.s. and get str8 to the problem... after removing the two bottom nuts (closest to the rotor), i began trying to remove the actual bolts that go thru the strut and they wont budge at all... i tried breaking them loose with a torque bar, nada... tried soaking them with a whole can of w-d40 and a couple light taps with a hammer, nada... then a lil more w-d40 with the torque bar again and im still getting nothing besides socket jump... needless to say im fed up... any tips on how to get out of this weak *** situation will be greatly appreciated...
Old Aug 14, 2009 | 03:56 AM
OneFast91Vert's Avatar
Car: 91 Camaro RS Vert
Engine: 305 TBI
Re: Stupid Suspension Problem... Help!!!
If you have an air compressor and impact gun try using that. It's the only way I survived that install. If not.....invest in one! It's well worth it.
Old Aug 14, 2009 | 04:22 AM
spr250's Avatar
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
Been a long time since I was under one, had to sell mine due to a divorce, anyway I don't remember the true setup under there but can you heat them up, just becareful and get 'em good and hot with a torque bar or better an impact wrench and keep trying.
Old Aug 14, 2009 | 04:15 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
its on there so tight it blew my impact gun, i'm almost scared to touch it with the wrench... i'm gonna try some pb blaster and go from there... last case scenario the things getting torched...
Old Aug 14, 2009 | 04:28 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Undo the nuts on the (edit) outside first. Use Liquid Wrench or JB-80 and heat it up to draw it in between the pieces. I used a long extension (must be heavy duty) about 3 feet long and use steady tension to ease it free while it's still warm.
Freeing the bolts may be difficult after removing the nuts. With the nuts removed use the penetrating fluid and heat to loosen the bolt while trying to turn it. Then get the same size nut from the hardware store and screw it on enough to protect the threads on the bolt and hammer it free. Repeat three more times. If you get stuck go to a different one for a while.
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You need a longer breaker bar. When I changed my struts, I used an 18" breaker bar with a 2' pipe over the end. I had to stand on the damn thing to get it to budge, but I got them off. Had to use the same setup to get them tightened back up to spec as well.
How do you have the control arm supported? If the arm is just hanging there unsupported and the top of the strut is still connected to the mount then the coil spring is pressing down on the strut bolts and will make them difficult to remove.
Old Aug 14, 2009 | 04:50 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
everything was done properly, car was up on jackstands and had a jack underneath the control arm... also i pretty much use the same breaker bar set up as you, just wouldnt budge at all... But it's all takin care of now!!! went completely ape s%#$ with a hammer and they popped out like it never happened... thanks guyz for the input!!
Old Aug 14, 2009 | 05:22 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Sorry for stating the obvious, but you never know.
Glad you got them out. Sometimes it just takes the persuasive end of a BFH to get the job done.
LT1Formula
Oct 8, 2015 08:34 PM
djmarch
Oct 2, 2015 10:41 PM
