front end bolt question
Old Aug 28, 2009 | 02:21 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
Just changed all the bushings in front end and checking everything.
I found on the drivers side where the sway bar bushing mount bolts to that bracket, the bolt facing down will not tighten. I acts like it is stripped. The bolt that goes in sideways above it is OK.
Is the one that won't tightenup bolting to frame or does it have a nut. There is no way I can get behind it to check it out. The frame and stearing box are in the way.
Old Aug 29, 2009 | 01:23 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: front end bolt question
Yes there is a captured nut that is supposed to be there for the bolt to thread into. It is very tight, but you should be able to squeeze your finger in to feel it and hold it in place to get the bolt to thread into it. If it is missing get a grade 8 nut and slip it in.
Lon
Old Sep 1, 2009 | 04:44 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
LarryL:
Is that a knight-rider front bumper?
kk
Old Sep 1, 2009 | 06:54 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
yes It is. This is a better view
Old Sep 1, 2009 | 07:16 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
Lon,
I have not been able to get at the nut. Is there anyway other than removing stearing box.
Old Sep 3, 2009 | 11:30 AM
LarryL
Check your PM.
Would like to chat some more about the bumper,
but not clog up this thread.
kk
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bellez77
Sep 5, 2015 08:39 PM
redmaroz
Aug 16, 2015 11:40 PM
