Different wheel gap on rear fenders...
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Hey,
I have noticed on my car lately that the top of the tire on the passenger side is probably around 5" while on the other side the gap is about 1" or less. I just put a used set of GR2's on the back. What could cause this. To state the obvious the tires are the same size lol, could it be I didn't tighten the passenger side shock enough or it worked loose or is something broke?
Thanks, Matt
Thanks, Matt
Re: Different wheel gap on rear fenders...
tweaked chasis......... has it always been like that or just since you replaced the shocks?
Car: 1987 Camaro
its seemed to have a hint of it prior to the shocks but not this bad, the right rear fender needs extensive body work as it was hit there before i got the car, we just got it looking as close we could instead of putting a new panel on, thats in the future...is there anyway of telling its tweaked? bodyshop?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Are both springs (and isolators) seated in the pocket correctly?
JamesC
JamesC
Car: 1987 Camaro
I think so, I have never had the rear springs out and I've had the car for 5 years...
Did you drop the rear end when you swapped in the shocks?
JamesC
JamesC
Car: 1987 Camaro
no i just jacked the car up unbolted them, and bolted in the new ones
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mine was always like that. It's more noticeable with wider tires. I don't think the third gen body is symmetrical from front to back or side to side.
mine sits 1/2" high on the rear right, and most of the 3rd gen cars i've seen seem to be the same way, the springs pockets in the rear aren't symetrical in my car, one is almost an inch deeper than the other, so that explains some of it but 5" thats a bit much
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my passengerside rear is 3/8" lower than the driverside
Car: 1987 Camaro
Ran out and did a quick measurement and I kind of overestimated...Its about 3/4 on the drivers side and about 2 and a 1/2 on the passenger side...
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
From what you guys are saying this seems fairly normal, another thing i'v noted is the spring perch's on 82 - 02 rearend's iv seen these out of whack and bent. something over looked.
Car: 1987 Camaro
ya im guessing between the fender being hit and messed up and everyone else having the same problem, that its nothing for me to worry about
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
You may have some bind in the sway bars too, if it really bothers you, you might want try doing the measurement with the sway bars unhooked on one side. Mine has always sat 1/2 higher on the passenger side.
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
Dang Kansans!
