Subframe Connectors Installed! Giving Me Good...Vibrations!?
Old Aug 31, 2009 | 11:28 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Today I had my set of UMI subframe connectors welded into the car. The car feels great. handles better and the car doesn't feel like I'ts twisting apart or about to flip over anymore. However...
From the second I pulled the car into the shop today, I noticed nothing out of the ordinary. When I went back and picked up the car and started driving it, I immediately noticed something that wasn't there before: a vibration. This vibration occurs around 1700RPM in any gear, but only when the car is moving not parked. I'm not talking a thump thump vibration, I'm talking the floorboards turn into a playstation dualshock controller vibration. It's not intense enough to the point where I think something is coming apart, but you definitely could not miss it to save your life. Is something screwed up or are the SFC's transferring vibrations that couldn't be felt before? I know one of the weld points is right where the floorboards are...
Anybody else experience this?
Old Sep 1, 2009 | 10:36 AM
UMI Sales's Avatar
Re: Subframe Connectors Installed! Giving Me Good...Vibrations!?
Hello
The sub frame connectors themselves should not be the problem! I sounds like one of two things. There is a installation problem or there might be a bad bushing on the transmission. Hope that helps!
Brad
Old Sep 1, 2009 | 10:42 AM
Car: 1985 Z28
Originally Posted by UMI Sales
Hello
Brad
o you are saying there is no way it is just the SFC's transferring vibrations through the floorboards? It only happens at this particular RPM, and let me add that it DOES in fact do it in Park as well.
This started the moment I picked it up from the shop. Also, there is no way it is the tranny mount It's only a 2 month old polyurethane mount from Spohn.
Old Sep 1, 2009 | 11:01 AM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
is vibration there all the time or just at 1700RPM (i assume that it continues to vibrate after that point too)
I would think if its being transferred through connector it would start as soon as you start to move the car, its weird that it dose it in park.
could they have installed them wrong? once they are put in thats the new shape of your car.
car must be level and have suspension under load.
Old Sep 1, 2009 | 11:07 AM
SystemX's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
Adding the SFCs probably changed the resonance frequency of your car so now it resonates with the engine/exhaust vibration at certain RPMs. My GTA developed a resonance type vibration after I put in my headers and duals. Just at certain RPMs while excellerating. Just my
Old Sep 1, 2009 | 12:30 PM
Car: 1985 Z28
This is the exact problem I'm having. It only vibrates at that one RPM level. Not above, or below.
Old Sep 1, 2009 | 02:53 PM
1988-305-tbi's Avatar
motor mounts.......
Old Sep 1, 2009 | 03:47 PM
Shagwell's Avatar
Car: projects.......
I'm sure the rigidity of the sfc's just multiplied/transfered the resonance/vibration.
Old Sep 1, 2009 | 03:56 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
SFC could be hittin the exhaust at the bend near the cat never used UMI before but could be the problem
Old Sep 1, 2009 | 04:09 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
motor mounts.
probably what happened is that your motor mounts are shot, and the engine is where it shouldnt be, causing the exhaust to come into contact with the subframe connectors.
the shop that put my SFC's in said that they had to heat up my y-pipe and bend it slightly so it wouldnt hit the SFC...
thats my guess
Old Sep 1, 2009 | 04:25 PM
Car: 1985 Z28
I called and talked to the guy who did the install and he said this is exactly what happened.
Old Sep 1, 2009 | 04:35 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
So has the situation been resolved by modifying the exhaust?
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
toronto formula
Nov 10, 2015 06:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
