alignment issue, seriously stumped!
Old Sep 3, 2009 | 10:33 PM
irocturn&burn's Avatar
Car: 91 Z28
Engine: aluminum block 5.3
Axle/Gears: 4th gen rear 4:10 welded
my 88 iroc has a problem in the rear axle mounting somewhere. the left rear wheel is 1.3'' closer to the front of the vehicle than the right rear wheel according to a hunter alignment machine. the car wanders a bit. i have replace both trailing arms. nothing underneath looks bent and is connected properly. there are no signs of the vehicle being wrecked either. the problem is still there even after i did a rear end swap from a 83 TA
Old Sep 3, 2009 | 10:50 PM
Guest
Guest
Posts: n/a
Re: alignment issue, seriously stumped!
Check your front A-arm bushings also. A-arm on the left could have a badly worn rear ear bushing.
Dean
Old Sep 4, 2009 | 04:56 PM
Car: 91 Z28
my front set back seems to be ok. if you stand back and concentrate really hard you can see the rear axle isnt sitting right. it was like that even before i swapped axles. although i dont doubt that the uni body may be shifted due to many hard miles
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
88rscamar0
Sep 23, 2015 09:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
