LCA's) Off-setting poly/other bushings other then rod ends?
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Would there be any binding or problems with doing this?
The idea is to put them in towards the rear end and tuck wider rubber in the wheel wells. I havent seen anyone make a set maybe theres a reason why. more strain on the welds?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LCA's) Off-setting poly/other bushings other then rod ends?
never seen anything other than rod ends for this, i dont see why somebody couldnt make one with poly. Spohn has some new Derlin bushed rod end things, maybe call them see if they can make offset ones
however, you can fit a 315 on the car without needing offset arms. Anything more than that you are looking at a LOT of sheetmetal/frame work. unless you dont mind the tires sticking out of the wheel wells.
Johnny joints. Problem solved.
Car: 87 GTA
You can get a the rod ended LCAs from UMI & a poly thread end, to to put place of one rod end.
But really....The double rod ends aren't all that bad. Slight vibration increase thought the pedal into your feet, but really not that bad, even on my 315/35/17s.
http://www.umiperformance.com/catalo...tinqrav0lovek3
Car: 86 Trans Am
You can build them offset if you want when you use the weld in type.
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
